Activity Forums Adobe After Effects final movie too big?
  • final movie too big?
    Posted by Cowgirrrl on December 8, 2005 at 1:42 pm
    hi, i’ve created a 1,30 min movie clip of footage with audio on 320×240…and the final size is over 200MB.
    which way to bring this significantly down (for people to download) without compromising on quality too much?
    thanks!
    Enzo Tedeschi replied 20 years, 9 months ago 4 Members · 6 Replies
  • Cowgirrrl
    December 8, 2005 at 1:54 pm
    i want to render it to a.mov file with the same size (320×240) for people to download from my ftp server…
  • Nicholas Toth
    December 8, 2005 at 1:58 pm
    sorenson squeeze…
    or when you export it use a different compression setting.
    Sorenson or sorenson 3 is good. cut your frame rate if it becomes and issue — goin from 15 to 30fps will DRASTICALLY cut your file size but kill your quality. Compression is an art within itself…
  • Cowgirrrl
    December 8, 2005 at 3:01 pm
    thanks…and does the file size drop a alot if i change the audio settings?
  • Cowgirrrl
    December 8, 2005 at 3:36 pm
    ok, so i’ve played around with sorenson and different settings and fps…and it is still 32MB? i want to send it as an attachment.
    Is there a tip to get it down to 1.2MB or so?
    Dont want to embarrass myself – it is for a job interview.
    please help!
  • Tim Kurkoski
    December 8, 2005 at 5:30 pm
    You’re going to have to play with the compression more. Getting even a minute of video down to under 5 MB requires a lot of compression. Basically, you’ll need to lower either the bitrate, the frame size, or the frame rate, or a combination of any of them.
    If you have QuickTime 7 installed, I’d recommend giving the H.264 codec a shot. Also, if you use the File > Export options instead of using the render queue, you can access more advanced compression settings. (Caveat: I’ve heard many people report problems when QT7 is on their machine, but I haven’t had any troubles myself.)
  • Enzo Tedeschi
    December 8, 2005 at 8:30 pm
    It’s always a delicate balance between size and quality. If you are compressing for delivery via broadband, I have found that quality is preferable to size, and I am pretty happy if I get my web stuff running at about 3Mb per minute of video. By far the best encoder on the Mac has been H.264 – really crisp encoding at lower bitrates. Far more efficient (with less fiddling) than the sorenson codec.
    If you encode down to a meg a minute – it’s gonna look pretty dodgy, I think, no matter what codec you use.
    e.
