Activity › Forums › Apple Final Cut Pro Legacy › Final Cuts Pro Page Turning Effect
  • Final Cuts Pro Page Turning Effect
    Posted by We Bulls wooble on March 28, 2007 at 2:29 pm
    I am working on making a graduation video and would like to make it appear that the album pages with multiple photographs on each page are being turned. Again I am not talking about turning individual pictures that would be a simple transition. How could I make this happen with the most recent version of Final Cuts Pro?
    Bret Williams replied 19 years, 6 months ago 4 Members · 3 Replies
  • Rafael Amador
    March 28, 2007 at 4:17 pm
    You need some other plugin Boris CC (Page Turn) or CGM (Page Peel) for example.
    Cheers,
    rafael
  • Steve Cohen
    March 28, 2007 at 5:05 pm
    Are you looking for the entire page to turn/peel with a radius or do you want the page to turn as if it is bound at the left or right edge?
    Either can be done with out any additional plugins.
    The first is simple,
    Build your page, Nest it and then apply the page turn to the entire nested sequence.
    The second is a bit tougher and requires motion to do or a new free plugin from Peter Wiggins I believe. I can’t remember the name of it right now it is now my system at home, not at work.
    Andt Mees says that he has a better 3D plugin at https://homepage.mac.com/andymees, but I have not tried it.
    Steve Cohen
    Editor
    O2 Media Inc.
  • Bret Williams
    March 29, 2007 at 3:48 am
    With stills, sometimes it’s even more convenient to build the page and then just press shift+n to make a freeze frame and drop it into the sequence where previously you had a stack of images. Then add the page turn.
