Activity Forums Apple Final Cut Pro Legacy Final Cut’s “Finder” “”browser bar” opens slow
  • Final Cut’s “Finder” “”browser bar” opens slow
    Posted by Phil Yunker on March 24, 2010 at 4:35 pm
    Not sure if this is the correct name for it but FCP’s “Finder” or browser bar opens slow.
    For example, when I click on any of the items (file, edit, view, mark, modify, sequence, effects, tool, window, help) they don’t open right away, usually 2-3 seconds, it’s has gone past annoying and now it’s really p&ssing me off.
    It seems to do it when I click on a different window (Viewer, canvas, Browser, timeline) then go to, for example “modify” it will take 2-3 seconds to open. Then when I move over to “mark” it will open immediately. Then when I click on a different window, for example the “browser” then back to “modify or “mark” or any of the items on the browser / nav bar / finder it takes 2-3 seconds to open. This also happens if I use the keyboard (not just the mouse) to select the window then try to click on one of the above items.
    I had 16GB of RAM in the system, I took it out and put in the original 2 GB of RAM to see if that would help (advice from a engineer friend) it did not help this problem but it might have cleared up another problem (more on that in another thread possibly).
    Any suggestions?
    FCP VER. 6.0.6
    System:
    10.5.8
    2 x 3.2 GHz Quad Core-Intel Xeon
    2 GB RAM (removed the 16GB RAM) WIll be putting it back in
    ATI Radeon HD 4870 /512 MB VRAM
    monitors – 1 x Samsung Synchmaster T240HD
    1 x Samsung Synchmaster T260
    PHIL YUNKER
    Yunker Video Production Services
    http://www.philyunker.com
    http://www.linkedin.com/in/philyunker
    Phil Yunker replied 16 years, 5 months ago 3 Members · 4 Replies
  • John Fishback
    March 24, 2010 at 4:50 pm
    If you haven’t trashed FCP prefs and Repaired Permissions try that. It’s the 1st thing to do when FCP suddenly gets weird.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.1, Motion 4.0.1, Comp 3.5.1, DVDSP 4.2.2, Color 1.5.1)
  • Phil Yunker
    March 24, 2010 at 5:46 pm
    John,
    Thanks. Yes I’ve done all that, no luck.
    PHIL YUNKER
  • Mike Kahn
    March 26, 2010 at 3:01 pm
    Try creating a new user account and opening FCP. Sometimes there are preferences that go bad that you don’t know about and simply creating a new user will fix this issue. If it does fix it, you can copy your files from one user to the other and delete the bad user.
  • Phil Yunker
    March 26, 2010 at 3:05 pm
    Mike,
    Thanks. I’ll try that.
    PHIL YUNKER
