Activity Forums Adobe Audition Final Cut XML import shows creates a session as 44.1k and not 48k
  • Final Cut XML import shows creates a session as 44.1k and not 48k
    Posted by Sean Scarfo on April 4, 2014 at 7:39 pm
    I don’t use Audition very much, so excuse me if I’m not using it correctly. (I’m a ProTools guy)
    In order to create a proper AAF/OMF, I’m asking editors to send me the media + a Final Cut XML file. When I import this into Audition, it always imports it as 44.1. (All the clips seem to be in the correct place though) I’ve tried exporting a Final Cut XML from Premiere as well as Sony Vegas, and I get the same thing. However, if I’m in Premiere and I send a sequence from Premiere to Audition, the sample rate is correct.
    Anyone know why the XML import into Audition is messed up?
    Sean Scarfo replied 12 years, 5 months ago 1 Member · 1 Reply
  • Sean Scarfo
    April 10, 2014 at 7:14 pm
    sigh… anyone?
