Activity › Forums › Apple Final Cut Pro › FINAL CUT X Project gone missing from the project Library how and why???
  • FINAL CUT X Project gone missing from the project Library how and why???
    Posted by King Law on February 9, 2013 at 4:06 pm
    I have been editing a project for over 4 days and this morning after turning my computer on its gone all the other projects are still in the project library how will get back my project?
    Susan Steinmetz replied 11 years, 4 months ago 4 Members · 5 Replies
  • Jeremy Garchow
    February 10, 2013 at 12:10 am
    Is it in the Finder?
  • King Law
    February 10, 2013 at 5:42 pm
    yes everything is in the finder the problem is when final cut start its loading all the projects in the project library accept for the one i was working on, the one i really need to work on 🙁
  • Jeremy Garchow
    February 11, 2013 at 3:38 am
    [King Law] “yes everything is in the finder the problem is when final cut start its loading all the projects in the project library accept for the one i was working on, the one i really need to work on :-(“
    In the Project folder, there should be a folder called “Backups”, in there should be a file.
    Take the “CurrentVersion.fcpproject” and move it to the desktop, duplicate the backup file in to the Project folder and rename it “CurrentVersion.fcpproject”.
    Does it work?
    Jeremy
  • Frank Lin
    June 17, 2013 at 9:41 am
    Thanks a lot, you saved me!!!
  • Susan Steinmetz
    May 10, 2015 at 8:22 pm
    What if the file’s not in the finder? I switched from one computer to another and the project i was working on is gone. the render files seem like they’re there though, I just figure out hoe to use them.
