Activity Forums Apple Final Cut Pro Legacy Final Cut X and SD cards
  • Final Cut X and SD cards
    Posted by Bryce Douglass on December 7, 2013 at 2:29 pm
    Is it possible to store events and projects on an SD card and use Final Cut X? I’m asking because I have two 2TB drives already using other stuff and my time machine backup takes forever to process cause I’m constantly using media. I’m thinking if I could store the Final Cut X projects and events on one SD card and the files on another I could use Final Cut that way and it would save space and time on my time machine backup.
    Sascha Engel replied 12 years, 9 months ago 3 Members · 2 Replies
  • John Fishback
    December 8, 2013 at 4:24 am
    It should work, although, the speed of the SD card will matter. If you have a couple of cards try it out.
    John
    MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.8.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
    FCP-X 10.0.9, Motion 5.0.7, Compressor 4.0.7
    Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
  • Sascha Engel
    December 18, 2013 at 6:28 am
    If you those files are important, make sure you have really good quality SD cards.
    I did experience in the past sometimes issues with cheaper models, such as Transcend Cards.
    Greetings,
    Sascha Engel
    TIME BANDITZ Productions
    http://www.youtube.com/taikang
