Activity Forums Apple Final Cut Pro Legacy Final Cut Won’t Open – EXC_BAD_ACCESS (SIGBUS) What’s happening?
  • Final Cut Won’t Open – EXC_BAD_ACCESS (SIGBUS) What’s happening?
    Posted by Peter Corbett on November 16, 2009 at 9:52 pm
    Very nervous here. I’ve had my new 10.6 8-core Mac Pro running okay for a week. I’m in the middle of cutting a commercial and concert program. Last night I saved and shutdown as normal.
    When I launched FCP7 this morning I got an error page with all this stuff below plus more. All I have is Adobe CS4 and Boris Continuum installed (plus FCS3). I uninstalled Boris but that made no difference. I know other users have CS4 on their Snow Leopard platforms with FCS3 so I don’t think that’s a problem. It’s been working perfectly, then I turn the Mac on this morning and this happens – but nothing’s changed.
    Should I reinstall FCS3? I’m new to Macs so I don’t want to lose all my jobs or RAID media.
    Peter
    Peter Corbett
    Powerhouse Productions
    http://www.php.com.au
    Scott Dedoes replied 16 years, 9 months ago 4 Members · 9 Replies
  • 9 Replies
  • Peter Corbett
    November 16, 2009 at 9:53 pm
    This is part of the error message plus there’s heaps more – too much to post
    Process: Final Cut Pro [216]
    Path: /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
    Identifier: com.apple.FinalCutPro
    Version: 7.0.1 (7.0.1)
    Build Info: FCPApp-910141802~4
    Code Type: X86 (Native)
    Parent Process: launchd [109]
    Date/Time: 2009-11-17 08:52:28.613 +1100
    OS Version: Mac OS X 10.6.2 (10C540)
    Report Version: 6
    Interval Since Last Report: 119047 sec
    Crashes Since Last Report: 8
    Per-App Interval Since Last Report: 152476 sec
    Per-App Crashes Since Last Report: 8
    Anonymous UUID: 87CEA5E3-11E1-4887-BFB9-980B6BE45DF9
    Exception Type: EXC_BAD_ACCESS (SIGBUS)
    Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
    Crashed Thread: 0 Dispatch queue: com.apple.main-thread
    Thread 0 Crashed: Dispatch queue: com.apple.main-thread
    Peter Corbett
  • Jeremy Garchow
    November 16, 2009 at 10:05 pm
    Have you trashed your preferences yet?
  • Peter Corbett
    November 16, 2009 at 10:20 pm
    Yep tried that. The only thing that changed between the last two cold boot-ups was that I installed Boros Continuum 6. I’ve uninstalled that without effect.
    Can I just reinstall FCP7 without doing any project damage?
    Peter Corbett
  • Jeremy Garchow
    November 16, 2009 at 10:48 pm
    [Peter Corbett] “Can I just reinstall FCP7 without doing any project damage?”
    Yes. I would use FCP Remover to totally clear it out, then reinstall FCP, then make sure to update the studio after you install it with Software update.
    Jeremy
  • Peter Corbett
    November 16, 2009 at 10:51 pm
    I think I sort of fixed it. Create a new Admin account, booted that, then did a cold boot on my original (crash-laden) account and FCP7 loads and works. Doing a bit of digging, this is all very dodgy as many users are experiencing this, but at random it appears. Apple must be aware that this is widespread.
    Peter Corbett
  • John Fishback
    November 17, 2009 at 9:03 pm
    Run DiskWarrior after your install. It’ll fix up your directory. This should be done even after a clean install. I just did a clean install and it was amazing how messed up the directory was.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Scott Dedoes
    December 10, 2009 at 12:24 am
    I am having similar problems trying to finalize a video project and apparently am not tech savvy enough to figure this out. Final Cut pro started crashing during the editing of a project and for a while I was able to get it to work by first opening up an older project first. Now I cannot get it to open at all. I have tried reinstalling and deleting the preferences. If anyone could help, I would be eternally grateful as I am going insane here.
    Here is the error log:
    I am having a similar problem with FCP 7 crashing on me, but it only seems to crash with one specific project file. When the problem started, I could open up another project first and then open the problem file and it would work fine, periodically crashing throughout. I am in the process of updating through Software update, but nothing seems to be working. I am fairly new to all this and would appreciate any help immensely. This is driving me insane.
    Process: Final Cut Pro [1671]
    Version: 7.0 (7.0)
    Build Info: FCPApp-906181654~22
    Parent Process: launchd [89]
    Date/Time: 2009-12-09 16:53:02.724 -0700
    OS Version: Mac OS X 10.6.1 (10B504)
    Report Version: 6
    Interval Since Last Report: 16298 sec
    Crashes Since Last Report: 1598
    Per-App Interval Since Last Report: 11580 sec
    Per-App Crashes Since Last Report: 24
    Anonymous UUID: 72D861F0-476B-409F-91C6-C46E8D280A27
    Exception Codes: KERN_PROTECTION_FAILURE at 0x000000003e67a000
    0 … Uncompressed 422.component 0x0b61d644 v210decode::CDDrawBand(v210decode*, ImageSubCodecDecompressRecord*) + 1188
    1 …ple.CoreServices.CarbonCore 0x96eb860c CallComponentFunctionCommonWithStorage(char**, ComponentParameters*, long (*)(), unsigned long) + 54
    2 … Uncompressed 422.component 0x0b61e58d v210decodeComponentDispatch + 205
    3 …ple.CoreServices.CarbonCore 0x96eb0cb6 CallComponentDispatch + 29
    4 …ickTimeComponents.component 0x930b1358 ImageCodecDrawBand + 43
    5 …ickTimeComponents.component 0x929f543e BaseCodec_DecompressWorkFunction + 1002
    6 …ickTimeComponents.component 0x929f5bc0 BaseCodec_DecompressCallBack_Common + 1328
    7 …ickTimeComponents.component 0x929f788f Base_CDBandDecompress + 5438
    8 …ple.CoreServices.CarbonCore 0x96eb860c CallComponentFunctionCommonWithStorage(char**, ComponentParameters*, long (*)(), unsigned long) + 54
    9 …ickTimeComponents.component 0x929f2cff Base_CDComponentDispatch + 127
    10 …ple.CoreServices.CarbonCore 0x96eb0cb6 CallComponentDispatch + 29
    11 com.apple.QuickTime 0x94572a40 ImageCodecBandDecompress + 43
    12 com.apple.QuickTime 0x94560b4d DoBandedDecompress + 17559
    13 com.apple.QuickTime 0x9455c4c9 ICMAction + 1177
    14 com.apple.QuickTime 0x9455b0d8 ICMDeviceLoop + 546
    15 com.apple.QuickTime 0x9456404c DecompressSequenceFrameWhen + 714
    16 …ickTimeComponents.component 0x928e3b78 v2m_rDecompressSequenceFrameWhen + 1092
    17 …ickTimeComponents.component 0x928e6e2a v2m_decompressVideoFrame + 609
    18 …ickTimeComponents.component 0x928ea9b6 QueueAFrame + 1595
    19 …ickTimeComponents.component 0x928eb8b6 v2m_doWhatTheMentorTellsUs + 1243
    20 …ickTimeComponents.component 0x928ef153 Video2MoviesTask + 2891
    21 …ple.CoreServices.CarbonCore 0x96ec3895 callComponentStorage_44444 + 49
    22 …ple.CoreServices.CarbonCore 0x96eb860c CallComponentFunctionCommonWithStorage(char**, ComponentParameters*, long (*)(), unsigned long) + 54
    23 …ickTimeComponents.component 0x928dc649 Video2ComponentDispatch + 212
    24 …ple.CoreServices.CarbonCore 0x96eb0cb6 CallComponentDispatch + 29
    25 com.apple.QuickTime 0x945b6087 MediaMoviesTask + 61
    26 com.apple.QuickTime 0x945b4e2c TaskMovie_priv + 4744
    27 com.apple.QuickTime 0x945c7b8e MoviesTask_priv + 101
    28 …alCutPro.Plugins.QTM Reader 0x0acbcd9d LongGOPChunkWriter::receiveSample(unsigned char const*, long long, unsigned long, long long, long long, SampleDescription**, unsigned long, unsigned long, long long, bool) + 21919
    29 …alCutPro.Plugins.QTM Reader 0x0accd095 PluginMainEntry(long, long, KGDictInt*, void*) + 7555
    30 com.apple.FinalCutPro 0x0024672f pKGGetFileVideo(KGDictInt*, double, long, unsigned char, KGCanvasRec*, KGRect*, KGDictInt*, KGFileRec*, unsigned long long, long) + 1615
    31 com.apple.FinalCutPro 0x0024e0ca GetItemFrame(KGDictInt*, KGClipItemType, WhenRec*, double, BufferInfoRec*, KGCanvasRec*, KGRect*, renderStackInfo*) + 728
    32 com.apple.FinalCutPro 0x0024f962 GetSpeedFrame(KGDictInt*, KGClipItemType, WhenRec*, double, BufferInfoRec*, KGCanvasRec*, KGRect*, renderStackInfo*, unsigned char*) + 3508
    33 com.apple.FinalCutPro 0x00254eed GetBlurFrame(KGDictInt*, KGClipItemType, WhenRec*, double, BufferInfoRec*, KGCanvasRec*, KGRect*, renderStackInfo*, unsigned char*) + 109
    34 com.apple.FinalCutPro 0x00256e33 GetTrackItemFrame(KGDictInt*, TrackInfoRec*, BufferInfoRec*, KGCanvasRec*, KGRect*, renderStackInfo*) + 5473
    35 com.apple.FinalCutPro 0x00258902 pKGGetClipVideoWithAlpha(double, long, KGCanvasRec*, KGRect*, long, KGDictInt*, AlphaType*, unsigned long long) + 5604
    36 com.apple.FinalCutPro 0x0024a62e pKGGetClipVideo(double, long, KGCanvasRec*, KGRect*, long, KGDictInt*, unsigned long long) + 80
    37 com.apple.FinalCutPro 0x00473ff4 CacheStillsRender(KGPlayerRec*, VideoPipe*, KGPlayerEditListStillInfo*, long*, KGRect*, KGItemSpec*, unsigned char) + 1522
    38 com.apple.FinalCutPro 0x004743fd CacheStillsRender(KGPlayerRec*, VideoPipe*, KGPlayerEditListStillInfo*, long*, KGRect*, KGItemSpec*, unsigned char) + 2555
    39 com.apple.FinalCutPro 0x004743fd CacheStillsRender(KGPlayerRec*, VideoPipe*, KGPlayerEditListStillInfo*, long*, KGRect*, KGItemSpec*, unsigned char) + 2555
    40 com.apple.FinalCutPro 0x0047443c CacheStillsRender(KGPlayerRec*, VideoPipe*, KGPlayerEditListStillInfo*, long*, KGRect*, KGItemSpec*, unsigned char) + 2618
    41 com.apple.FinalCutPro 0x004743fd CacheStillsRender(KGPlayerRec*, VideoPipe*, KGPlayerEditListStillInfo*, long*, KGRect*, KGItemSpec*, unsigned char) + 2555
    42 com.apple.FinalCutPro 0x0047443c CacheStillsRender(KGPlayerRec*, VideoPipe*, KGPlayerEditListStillInfo*, long*, KGRect*, KGItemSpec*, unsigned char) + 2618
    43 com.apple.FinalCutPro 0x00476743 CacheStills(KGPlayerRec*, VideoPipe*, PipeSegmentInfo*, KGListRecord*, long*, KGPlayerEditListStillInfo*, cacheStillsRtPlayerValues*) + 1857
    44 com.apple.FinalCutPro 0x0048a22e MakeVideoCache(KGPlayerRec*, double, double, unsigned char, long*) + 4250
    45 com.apple.FinalCutPro 0x0048d9ec RebuildCache(KGPlayerRec*, unsigned char) + 5714
    46 com.apple.FinalCutPro 0x001ca8bc SetPlayerCanvas(KGPlayerRec*, KGCanvasRec*, KGRect*, KGRect*, unsigned char) + 246
    47 com.apple.FinalCutPro 0x001cb0f9 KGPlayerNewFull(KGDictInt*, KGCanvasRec*, KGRect*, KGRect*, KGRect*, KGRect*) + 185
    48 com.apple.FinalCutPro 0x001d9c0c pKGPlayerNewView(KGViewRecord*, char*, KGRect*, KGDictInt*, unsigned long) + 1636
    49 …CutPro.Plugins.Movie Viewer 0x0ab71f3a MovieViewer(long, long, KGDictInt*, KGFileRec*) + 27288
    50 com.apple.FinalCutPro 0x002365a7 DisplayClipCore(KGDictInt*, char*, KGDictInt*, unsigned char) + 583
    51 com.apple.FinalCutPro 0x00236d8a pKGPresentClip(KGDictInt*, KGPresentClipOptions, KGDictInt*) + 1794
    52 …FinalCutPro.Plugins.Browser 0x0a819697 RecordOpenItems(KGDictInt*, KGViewRecord*) + 1921
    53 …FinalCutPro.Plugins.Browser 0x0a819a33 RestoreOpenItems(KGDictInt*, KGViewRecord*) + 335
    54 …FinalCutPro.Plugins.Browser 0x0a7c871e BrowserOpenFile(KGFileRec*, unsigned char, unsigned char, KGDictInt**) + 5216
    55 …FinalCutPro.Plugins.Browser 0x0a7cb42d Browser(long, long, KGDictInt*, KGFileRec*) + 10299
    56 com.apple.FinalCutPro 0x0018cf9c CheckForOpenFile(KGFileSpec*, char*, unsigned char, unsigned char, KGDictInt**) + 488
    57 com.apple.FinalCutPro 0x0018d0d0 pKGDisplayFile(KGFileSpec*, char*, unsigned char, unsigned char) + 44
    58 com.apple.FinalCutPro 0x001a972a pKGPromptOpen() + 170
    59 com.apple.FinalCutPro 0x001a9f96 DefaultMenuHandler(long, long, KGDictInt*, void*) + 802
    60 com.apple.FinalCutPro 0x001515c5 HandleMenuCommand(long, unsigned char, unsigned char, unsigned char, KGErrorCode (*)(long, long, KGDictInt*, void*), void*) + 325
    61 com.apple.FinalCutPro 0x00151797 HandleCommand(long, unsigned char, unsigned char, unsigned char) + 263
    62 com.apple.FinalCutPro 0x00414efb CommandProcess(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 369
    63 com.apple.HIToolbox 0x90bdf129 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567
    64 com.apple.HIToolbox 0x90bde3f0 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
    65 com.apple.HIToolbox 0x90c00a81 SendEventToEventTarget + 52
    66 com.apple.HIToolbox 0x90c2cf3b SendHICommandEvent(unsigned long, HICommand const*, unsigned long, unsigned long, unsigned char, void const*, OpaqueEventTargetRef*, OpaqueEventTargetRef*, OpaqueEventRef**) + 448
    67 com.apple.HIToolbox 0x90c51c1c SendMenuCommandWithContextAndModifiers + 66
    68 com.apple.HIToolbox 0x90c51bd1 SendMenuItemSelectedEvent + 121
    69 com.apple.HIToolbox 0x90c51ad3 FinishMenuSelection(SelectionData*, MenuResult*, MenuResult*) + 152
    70 com.apple.HIToolbox 0x90c212ed MenuSelectCore(MenuData*, Point, double, unsigned long, OpaqueMenuRef**, unsigned short*) + 440
    71 com.apple.HIToolbox 0x90dd313f MenuSelect + 190
    72 com.apple.HIToolbox 0x90d8c530 HIMenuBar::HandleMouseEvent(OpaqueEventRef*) + 92
    73 com.apple.HIToolbox 0x90bdf723 HIObject::EventHook(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 173
    74 com.apple.HIToolbox 0x90bdf129 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567
    75 com.apple.HIToolbox 0x90bde3f0 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
    76 com.apple.HIToolbox 0x90c00a81 SendEventToEventTarget + 52
    77 com.apple.HIToolbox 0x90c125d7 ToolboxEventDispatcherHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 1417
    78 com.apple.HIToolbox 0x90bdf57a DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 2672
    79 com.apple.HIToolbox 0x90bde3f0 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
    80 com.apple.HIToolbox 0x90c00a81 SendEventToEventTarget + 52
    81 com.apple.HIToolbox 0x90d898f7 ToolboxEventDispatcher + 86
    82 com.apple.HIToolbox 0x90d89a2f RunApplicationEventLoop + 243
    83 com.apple.FinalCutPro 0x0015464f KGMainEvent(void*) + 51
    84 com.apple.FinalCutPro 0x002c1aa8 main + 54
    85 com.apple.FinalCutPro 0x00003a6b _start + 209
    86 com.apple.FinalCutPro 0x00003999 start + 41
    Thread 1: Dispatch queue: com.apple.libdispatch-manager
    0 libSystem.B.dylib 0x94af503a kevent + 10
    1 libSystem.B.dylib 0x94af5768 _dispatch_mgr_invoke + 215
    2 libSystem.B.dylib 0x94af4bf9 _dispatch_queue_invoke + 183
    3 libSystem.B.dylib 0x94af498a _dispatch_worker_thread2 + 234
    4 libSystem.B.dylib 0x94af4401 _pthread_wqthread + 390
    5 libSystem.B.dylib 0x94af4246 start_wqthread + 30
    Thread 2:
    0 libSystem.B.dylib 0x94aed756 select$DARWIN_EXTSN + 10
    1 com.apple.CoreFoundation 0x93f1904d __CFSocketManager + 1085
    2 libSystem.B.dylib 0x94afbf39 _pthread_start + 345
    3 libSystem.B.dylib 0x94afbdbe thread_start + 34
    Thread 3:
    0 libSystem.B.dylib 0x94ace822 semaphore_wait_signal_trap + 10
    1 libSystem.B.dylib 0x94afc3d8 _pthread_cond_wait + 1089
    2 libSystem.B.dylib 0x94b4570f pthread_cond_wait + 48
    3 com.apple.FinalCutPro 0x0043ee7b Synchronizable::Wait() + 53
    4 com.apple.FinalCutPro 0x00429495 DisplayQueue::Run() + 681
    5 com.apple.FinalCutPro 0x0046ac0c Thread::RunHelper(void*) + 20
    6 libSystem.B.dylib 0x94afbf39 _pthread_start + 345
    7 libSystem.B.dylib 0x94afbdbe thread_start + 34
    Thread 4:
    4 com.apple.FinalCutPro 0x004e5a4b WorkUnitPerformer::Run() + 55
    Thread 5:
    0 libSystem.B.dylib 0x94ace7da mach_msg_trap + 10
    1 libSystem.B.dylib 0x94acef47 mach_msg + 68
    2 com.apple.CoreFoundation 0x93ed9dbf __CFRunLoopRun + 2447
    3 com.apple.CoreFoundation 0x93ed8d34 CFRunLoopRunSpecific + 452
    4 com.apple.CoreFoundation 0x93ede7a4 CFRunLoopRun + 84
    5 com.apple.DVCPROHDMuxer 0x0fd8b98f AVS::DestroyAVCDeviceController(AVS::AVCDeviceController*) + 317
    Thread 6:
    4 com.apple.CoreFoundation 0x93ed8b61 CFRunLoopRunInMode + 97
    5 ….CoreMediaIOServicesPrivate 0x0101fa3f MIO::DAL::RunLoop::OwnThread(void*) + 157
    6 ….CoreMediaIOServicesPrivate 0x010218b0 CAPThread::Entry(CAPThread*) + 96
    7 libSystem.B.dylib 0x94afbf39 _pthread_start + 345
    8 libSystem.B.dylib 0x94afbdbe thread_start + 34
    Thread 7:
    5 com.apple.qmaster.do 0x3215b3b2 swamp::CRAdReceiver2::ReceivingThread::runOnce() + 234
    6 com.apple.AECore 0x22a0c092 aecore::CThread::runThread() + 34
    7 com.apple.AECore 0x22a0a029 threadProc(void*) + 17
    8 libSystem.B.dylib 0x94afbf39 _pthread_start + 345
    9 libSystem.B.dylib 0x94afbdbe thread_start + 34
    Thread 8:
    1 com.apple.AECore 0x22a0c0d7 aecore::CThread::runThread() + 103
    2 com.apple.AECore 0x22a0a029 threadProc(void*) + 17
    3 libSystem.B.dylib 0x94afbf39 _pthread_start + 345
    4 libSystem.B.dylib 0x94afbdbe thread_start + 34
    Thread 9:
    0 libSystem.B.dylib 0x94ace83a semaphore_timedwait_signal_trap + 10
    1 libSystem.B.dylib 0x94afc3c1 _pthread_cond_wait + 1066
    2 libSystem.B.dylib 0x94b2b208 pthread_cond_timedwait_relative_np + 47
    3 …ple.CoreServices.CarbonCore 0x96e90435 TSWaitOnConditionTimedRelative + 242
    4 …ple.CoreServices.CarbonCore 0x96e90173 TSWaitOnSemaphoreCommon + 511
    5 …ickTimeComponents.component 0x928c6255 ReadSchedulerThreadEntryPoint + 4698
    Thread 10:
    5 …ple.CoreServices.CarbonCore 0x96eea674 AIOFileThread(void*) + 1127
    Thread 11:
    0 libSystem.B.dylib 0x94af4092 __workq_kernreturn + 10
    1 libSystem.B.dylib 0x94af4628 _pthread_wqthread + 941
    2 libSystem.B.dylib 0x94af4246 start_wqthread + 30
    Thread 12:
    5 com.apple.DesktopServices 0x93d762a9 TSystemNotificationTask::SystemNotificationTaskProc(void*) + 643
    6 …ple.CoreServices.CarbonCore 0x96e6f9fa PrivateMPEntryPoint + 68
    Thread 13:
    Thread 14:
    3 …ickTimeComponents.component 0x92a335b7 jpegdecompress_MPLoop + 79
    4 libSystem.B.dylib 0x94afbf39 _pthread_start + 345
    5 libSystem.B.dylib 0x94afbdbe thread_start + 34
    Thread 0 crashed with X86 Thread State (32-bit):
    eax: 0x7f8100ff ebx: 0x0b61d1b4 ecx: 0x107f1081 edx: 0x0000007f
    edi: 0x3e67a000 esi: 0x00000000 ebp: 0xbfff8558 esp: 0xbfff84a0
    ss: 0x0000001f efl: 0x00010282 eip: 0x0b61d644 cs: 0x00000017
    ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
    cr2: 0x3e67a000
    Binary Images:
    0x1000 – 0x867ffc com.apple.FinalCutPro 7.0 (7.0) /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
    0xc22000 – 0xc25ff7 +KGCore ??? (???) <51356927-1E64-52FC-E38B-637BC74EC30F> /Applications/Final Cut Pro.app/Contents/Frameworks/KGCore.framework/Versions/A/KGCore
    0xc2d000 – 0xc2dff7 com.apple.iokit.dvcomponentglue 1.9.9 (1.9.9) <2BA05DB9-D847-CBC7-42D6-A9D96D7E1ED2> /System/Library/Frameworks/DVComponentGlue.framework/Versions/A/DVComponentGlue
    0xc31000 – 0xc40fff com.apple.AERegistration 1.2 (77) <0C4C1300-9E3A-E2A1-4507-380C2544B223> /Applications/Final Cut Pro.app/Contents/Frameworks/AERegistration.framework/Versions/A/AERegistration
    0xc54000 – 0xc5bfff com.apple.AEProfiling 1.2 (22) <50FD5623-D2C1-8102-FD41-D8E745E08353> /Applications/Final Cut Pro.app/Contents/Frameworks/AEProfiling.framework/Versions/A/AEProfiling
    0xc65000 – 0xe18feb com.apple.prokit 5.0.1 (906) /System/Library/PrivateFrameworks/ProKit.framework/Versions/A/ProKit
    0xed7000 – 0xf49fef com.apple.ProFX 1.2.3 (1.2.3) /Library/Application Support/ProApps/SharedA/Frameworks/ProFX.framework/Versions/A/ProFX
    0xf6b000 – 0xfc5ff7 com.apple.proapps.MIO 1.0 (498) <1FFA992F-4D82-684F-B205-4C9015BA14FA> /Applications/Final Cut Pro.app/Contents/Frameworks/MIO.framework/Versions/A/MIO
    0x1001000 – 0x100aff7 com.apple.finalcutstudio.prometadatasupport 0.6 (1.0) /Library/Frameworks/ProMetadataSupport.framework/Versions/A/ProMetadataSupport
    0x1012000 – 0x104cfff com.apple.CoreMediaIOServicesPrivate 22.0 (814) <596EF646-C29C-1B9E-4FE3-8301C1648381> /System/Library/PrivateFrameworks/CoreMediaIOServicesPrivate.framework/Versions/A/CoreMediaIOServicesPrivate
    0x1068000 – 0x1091ff7 com.apple.CoreMediaPrivate 20.0 (20.0) <29A9848F-2C1C-BDE4-EADC-2A3C71C1DBC4> /System/Library/PrivateFrameworks/CoreMediaPrivate.framework/Versions/A/CoreMediaPrivate
    0x10a4000 – 0x10d7ff3 com.apple.FWAVCPrivate 1.46 (46) /System/Library/PrivateFrameworks/FWAVCPrivate.framework/Versions/A/FWAVCPrivate
    0x10ec000 – 0x110afef com.apple.XSKey 1.0.0 (52) <71B94F53-15DB-9012-91F2-211F7C2CD790> /Library/Frameworks/XSKey.framework/Versions/A/XSKey
    0x1119000 – 0x11cefe7 libcrypto.0.9.7.dylib ??? (???) <4917E4F2-817F-5AC4-3FBE-54BC96360448> /usr/lib/libcrypto.0.9.7.dylib
    0x1259000 – 0x1299ff7 com.apple.vmutils 4.2 (106) <834EA6B0-C91B-4CF1-ED3C-229C26459578> /System/Library/PrivateFrameworks/vmutils.framework/vmutils
    0x960d000 – 0x9615ff7 com.apple.proapps.mrcheckpro 1.4 (359) <353F1A07-BA95-60CD-D083-4537D209BB69> /Applications/Final Cut Pro.app/Contents/Resources/MRCheckPro.bundle/Contents/MacOS/MRCheckPro
    0x9693000 – 0x9697ff3 com.apple.FinalCutPro.Plugins.AudioGroupsExport 7.0 (7.0) <1A97986C-80FA-E8A2-E3F1-36442967EDE0> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/AudioGroupsExport.bundle/Contents/MacOS/AudioGroupsExport
    0x96fe000 – 0x971aff7 GLRendererFloat ??? (???) /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFloat
    0x9744000 – 0x976eff7 com.apple.FinalCutPro.Plugins.AfterEffects 7.0 (7.0) <12DF4BD0-EF34-BFDB-D486-73331325BAFC> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/AfterEffects.bundle/Contents/MacOS/AfterEffects
    0x9776000 – 0x977bfff com.apple.FinalCutPro.Plugins.Cache Manager 7.0 (7.0) <5B5A8A92-59E9-29DF-FC04-C3E741BFDDE3> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Cache Manager.bundle/Contents/MacOS/Cache Manager
    0x9780000 – 0x9783ffc com.apple.FinalCutPro.Plugins.FinalTouchExport 7.0 (7.0) <4A3A19C3-45BB-5401-91E8-E4F44D15ECEA> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FinalTouchExport.bundle/Contents/MacOS/FinalTouchExport
    0xa06f000 – 0xa1e0ff7 GLEngine ??? (???) <132E6F18-BD3F-53AC-8448-2B68A83B0393> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
    0xa211000 – 0xa5b7ffb libclh.dylib ??? (???) /System/Library/Extensions/GeForce8xxxGLDriver.bundle/Contents/MacOS/libclh.dylib
    0xa5d2000 – 0xa5e9ff3 com.apple.FinalCutPro.Plugins.AudioMixer 7.0 (7.0) <88F6D4E7-2CBF-7711-9F64-AE4F960FD2F4> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/AudioMixer.bundle/Contents/MacOS/AudioMixer
    0xa5f4000 – 0xa5f8fff com.apple.FinalCutPro.Plugins.LayerFileReader 7.0 (7.0) <3E6E6504-22D7-E840-6B79-C0629CDEF396> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/LayerFileReader.bundle/Contents/MacOS/LayerFileReader
    0xa5fd000 – 0xa5fdff7 libmx.A.dylib ??? (???) <01401BF8-3FC7-19CF-ACCE-0F292BFD2F25> /usr/lib/libmx.A.dylib
    0xa700000 – 0xa74cfff com.apple.audio.midi.CoreMIDI 1.7 (42) <670CB7F9-AA00-86F3-6623-E1335F7AEA83> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
    0xa771000 – 0xa79bfeb com.apple.proapps.ControlSurfaceSupport 2.0 (68) <86163AA6-65BF-CD27-1AB4-D40199CA8269> /Applications/Final Cut Pro.app/Contents/Frameworks/ControlSurfaceSupport.framework/Versions/A/ControlSurfaceSupport
    0xa7bc000 – 0xa894ff2 com.apple.FinalCutPro.Plugins.Browser 7.0 (7.0) <298F68CA-BB0D-ACA0-7196-7E24032020DA> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Browser.bundle/Contents/MacOS/Browser
    0xa8b2000 – 0xa8ccfff com.apple.FinalCutPro.CinemaTools 5.0 (5.0) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Cinema Tools.bundle/Contents/MacOS/Cinema Tools
    0xa8d8000 – 0xa8e2ff9 com.apple.FinalCutPro.Plugins.CTHelper 7.0 (7.0) <4E702488-DED7-34FC-926A-1DFE89685E00> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/CTHelper.bundle/Contents/MacOS/CTHelper
    0xa8e9000 – 0xa90fff7 com.apple.FinalCutPro.Plugins.EditTape 7.0 (7.0) <7D39D978-72FF-C63B-2C45-5CCA7F2265AF> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/EditTape.bundle/Contents/MacOS/EditTape
    0xa91e000 – 0xa978ff5 com.apple.FinalCutPro.Plugins.EDL Export 7.0 (7.0) <074F25E4-EFCE-90E7-F539-97B9F1227303> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/EDL Export.bundle/Contents/MacOS/EDL Export
    0xa98d000 – 0xa995fff com.apple.FinalCutPro.Plugins.Effect Builder 7.0 (7.0) <935F0D8E-B033-70AF-C80B-D94ED7EBB82B> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Effect Builder.bundle/Contents/MacOS/Effect Builder
    0xa99a000 – 0xa9a5ffe com.apple.FinalCutPro.Plugins.FCPExtPluginSupport 7.0 (7.0) <456A6BBC-75A0-5914-FFAD-7ED1020DB313> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FCPExtPluginSupport.bundle/Contents/MacOS/FCPExtPluginSupport
    0xa9ae000 – 0xa9e1ff7 com.apple.FinalCutPro.Plugins.FCS Engine 7.0 (7.0) <8C4A49F7-0E3E-9665-D239-D5F1FC6C0DA8> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FCS Engine.bundle/Contents/MacOS/FCS Engine
    0xa9eb000 – 0xa9fcff7 com.apple.FinalCutPro.Plugins.FilterCustomEd 7.0 (7.0) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FilterCustomEd.bundle/Contents/MacOS/FilterCustomEd
    0xaa02000 – 0xaa17ffb com.apple.FinalCutPro.Plugins.FilterViewer 7.0 (7.0) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FilterViewer.bundle/Contents/MacOS/FilterViewer
    0xaa1d000 – 0xaa3bfea com.apple.FinalCutPro.Plugins.Flash 7.0 (7.0) <7042D12F-1308-9D6A-FBFD-C04480954ADC> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Flash.bundle/Contents/MacOS/Flash
    0xaa47000 – 0xaa54ffb com.apple.FinalCutPro.Plugins.GenViewer 7.0 (7.0) <40E4BDD5-6095-D88E-4011-E350AE87290B> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/GenViewer.bundle/Contents/MacOS/GenViewer
    0xaa5a000 – 0xaaa6ff3 com.apple.FinalCutPro.Plugins.Media Manager 7.0 (7.0) <7256BCAE-C22F-0A2E-0D25-B0E99F7AED53> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Media Manager.bundle/Contents/MacOS/Media Manager
    0xaab0000 – 0xaac2ff0 com.apple.FinalCutPro.Plugins.MolokiniSupport 7.0 (7.0) <45FF9473-7105-1E59-4C0C-71B6D6E9E952> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/MolokiniSupport.bundle/Contents/MacOS/MolokiniSupport
    0xaad1000 – 0xaae5fff com.apple.FinalCutPro.Frameworks.MolokiniTranslation 1.0 (1.0) /Applications/Final Cut Pro.app/Contents/Frameworks/MolokiniTranslation.framework/Versions/A/MolokiniTranslation
    0xaaf3000 – 0xab25ffb com.apple.FinalCutPro.Plugins.Motion Viewer 7.0 (7.0) <853FBBC7-2628-C483-AEBC-AC69B8A61D0C> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Motion Viewer.bundle/Contents/MacOS/Motion Viewer
    0xab36000 – 0xab51ff3 com.apple.FinalCutPro.Plugins.Movie Analyzer 7.0 (7.0) <3A3417F4-73E4-447E-D1B1-1D8888230801> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Movie Analyzer.bundle/Contents/MacOS/Movie Analyzer
    0xab60000 – 0xab76ffb com.apple.FinalCutPro.Plugins.Movie Viewer 7.0 (7.0) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Movie Viewer.bundle/Contents/MacOS/Movie Viewer
    0xab82000 – 0xab86fff com.apple.FinalCutPro.Plugins.NuggetExport 7.0 (7.0) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/NuggetExport.bundle/Contents/MacOS/NuggetExport
    0xab8b000 – 0xac44fe7 com.apple.FinalCutPro.Plugins.OMF Audio Export 7.0 (7.0) <7E770367-D26F-A1BE-5F90-E5A915A6477D> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/OMF Audio Export.bundle/Contents/MacOS/OMF Audio Export
    0xac57000 – 0xac5fffb com.apple.FinalCutPro.Plugins.Perf Analyzer 7.0 (7.0) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Perf Analyzer.bundle/Contents/MacOS/Perf Analyzer
    0xac64000 – 0xac79ffb com.apple.FinalCutPro.Plugins.ProAppsIntegration 7.0 (7.0) <9770E1E4-FB6F-AFE0-6213-76E583255FCD> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/ProAppsIntegration.bundle/Contents/MacOS/ProAppsIntegration
    0xac89000 – 0xac96ff7 com.apple.FinalCutPro.Plugins.Pulldown Support 7.0 (7.0) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Pulldown Support.bundle/Contents/MacOS/Pulldown Support
    0xac9e000 – 0xacddfef com.apple.FinalCutPro.Plugins.QTM Reader 7.0 (7.0) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/QTM Reader.bundle/Contents/MacOS/QTM Reader
    0xacea000 – 0xacf2ff3 com.apple.FinalCutPro.Plugins.QuickView 7.0 (7.0) <1FEC8B5F-4E5E-CE95-260A-1566CD44C5D3> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/QuickView.bundle/Contents/MacOS/QuickView
    0xacf7000 – 0xad07ffe com.apple.FinalCutPro.Plugins.Relink Media 7.0 (7.0) <00B1CB9D-18F0-EF7E-B47F-4AD62B817B80> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Relink Media.bundle/Contents/MacOS/Relink Media
    0xad0e000 – 0xad0ffff com.apple.FinalCutPro.Plugins.Text Window 7.0 (7.0) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Text Window.bundle/Contents/MacOS/Text Window
    0xad14000 – 0xadadff2 com.apple.FinalCutPro.Plugins.Timeline Editor 7.0 (7.0) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Timeline Editor.bundle/Contents/MacOS/Timeline Editor
    0xadbc000 – 0xadcdfff com.apple.FinalCutPro.Plugins.Transcoder 7.0 (7.0) <342DBF2C-0E48-35D2-6F07-FAD4E3061902> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Transcoder.bundle/Contents/MacOS/Transcoder
    0xadd7000 – 0xade9fff com.apple.FinalCutPro.Plugins.Transition Viewer 7.0 (7.0) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Transition Viewer.bundle/Contents/MacOS/Transition Viewer
    0xadef000 – 0xae04ff3 com.apple.FinalCutPro.Plugins.Trimming 7.0 (7.0) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Trimming.bundle/Contents/MacOS/Trimming
    0xae0a000 – 0xae10ffb com.apple.FinalCutPro.Plugins.VDUSupport 7.0 (7.0) <9F7E6DE6-9346-FA87-DD51-7A7AB41470F2> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/VDUSupport.bundle/Contents/MacOS/VDUSupport
    0xae16000 – 0xae17ffb com.apple.FinalCutPro.Plugins.Vector Accelerator 7.0 (7.0) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Vector Accelerator.bundle/Contents/MacOS/Vector Accelerator
    0xae1c000 – 0xae2dfff com.apple.FinalCutPro.Plugins.VideoLog 7.0 (7.0) <4817E207-3AB8-C009-5D5D-61FD5D749536> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/VideoLog.bundle/Contents/MacOS/VideoLog
    0xae32000 – 0xae4aff7 com.apple.FinalCutPro.Plugins.VoiceOver 7.0 (7.0) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/VoiceOver.bundle/Contents/MacOS/VoiceOver
    0xae51000 – 0xaecdfe5 com.apple.FinalCutPro.Plugins.XML Support 7.0 (7.0) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/XML Support.bundle/Contents/MacOS/XML Support
    0xb2f8000 – 0xb2faff3 com.apple.LiveType.component 2.1.4 (2.1.4) /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
    0xb445000 – 0xb452fff +net.telestream.license 1.0.3.4-GC (1.0.3.4-GC) <0B4D5758-8A9B-958D-1406-12377A1D9E23> /Library/Frameworks/TSLicense.framework/Versions/A/TSLicense
    0xb45b000 – 0xb460ffb com.apple.AppleMPEG2Codec 1.0.1 (220) /Library/QuickTime/AppleMPEG2Codec.component/Contents/MacOS/AppleMPEG2Codec
    0xb617000 – 0xb628fe7 com.apple.FCP Uncompressed 422.component 1.6 (1.6) <5CEF993F-DBAC-12FD-57C6-EFA42AB7AEE2> /Library/QuickTime/FCP Uncompressed 422.component/Contents/MacOS/FCP Uncompressed 422
    0xb62f000 – 0xb63eff7 com.apple.QuartzComposer.FxPlugWrapper 1.2.3 (92) <38A3D1ED-F563-7690-3AB6-80B15FD286A2> /Library/Application Support/ProApps/SharedA/Plug-Ins/ProFX/FxPlugWrapper.plugin/Contents/MacOS/FxPlugWrapper
    0xb67a000 – 0xb6defe2 com.apple.LiveType.framework 2.1.4 (2.1.4) <19C0FA03-FC58-CCFE-395D-DD4125A0B811> /Library/Application Support/ProApps/SharedA/Frameworks/LiveType.framework/Versions/A/LiveType
    0xb6fe000 – 0xb712fef com.apple.fcp.DVOutputUnit 1.3 (1.3) <28E28BC6-01A0-34B2-8F64-474F521105C8> /Applications/Final Cut Pro.app/Contents/Resources/DVOutputUnit.bundle/Contents/MacOS/DVOutputUnit
    0xb9c2000 – 0xba2ffe7 com.apple.AppleProResCodec 2.0 (224) /Library/QuickTime/AppleProResCodec.component/Contents/MacOS/AppleProResCodec
    0xba7c000 – 0xbe58fe3 QuickTimeH264.scalar ??? (???) <80C41CA7-B837-278A-BD85-625F676FC9D2> /System/Library/QuickTime/QuickTimeH264.component/Contents/Resources/QuickTimeH264.scalar
    0xbeb2000 – 0xbee9fe7 com.apple.DVCPROHDCodec 1.5 (237) <5BA42205-5AEE-73BB-A7DE-5417EF028D5B> /Library/QuickTime/DVCPROHDCodec.component/Contents/MacOS/DVCPROHDCodec
    0xbef9000 – 0xbfa8fe3 com.apple.AppleHDVCodec 1.5 (228) <8D2121A0-BA53-28A2-C9A5-3BED137701DA> /Library/QuickTime/AppleHDVCodec.component/Contents/MacOS/AppleHDVCodec
    0xbfd0000 – 0xbfeafeb com.apple.AppleIntermediateCodec 1.3 (151) <038597CB-32E7-EBA5-F816-24ED96182EA4> /Library/QuickTime/AppleIntermediateCodec.component/Contents/MacOS/AppleIntermediateCodec
    0xbff0000 – 0xc003fe3 com.apple.IMXCodec 1.4 (155) /Library/QuickTime/IMXCodec.component/Contents/MacOS/IMXCodec
    0xc015000 – 0xc02efe7 com.apple.applepixletvideo 1.2.19 (1.2d19) <4A68731C-8071-6CF5-012C-40F00CD1333A> /System/Library/QuickTime/ApplePixletVideo.component/Contents/MacOS/ApplePixletVideo
    0xc033000 – 0xc06ffe3 com.apple.QuickTimeFireWireDV.component 7.6.3 (1584) <8E3D38A3-1005-305C-7B70-D400AB4AC0F3> /System/Library/QuickTime/QuickTimeFireWireDV.component/Contents/MacOS/QuickTimeFireWireDV
    0xc1b4000 – 0xc1c0fff com.apple.PluginManager 1.7.3 (34) <13CD3A05-A00C-4FA7-AD61-2A706A67E390> /Library/Frameworks/PluginManager.framework/Versions/B/PluginManager
    0xc1cd000 – 0xc1ceff7 com.apple.Helium 3.0.1 (225) /Library/Application Support/ProApps/SharedA/Frameworks/Helium.framework/Versions/A/Helium
    0xc1d2000 – 0xc1d2fff com.apple.FxHeliumImage 4.0.0 (1.0) <2CA40CA6-C2E5-D8B8-255D-B8544AE206DD> /Library/Application Support/ProApps/SharedA/Frameworks/FxHeliumImage.framework/Versions/A/FxHeliumImage
    0xc1d8000 – 0xc1dcff3 com.apple.SmoothCamFxPlug 1.0.1 (1.0.1) <50A3C873-3B3F-0E6E-342A-6E191584750A> /Library/Application Support/ProApps/SharedA/Plug-Ins/FxPlug/SmoothCam.fxplug/Contents/MacOS/SmoothCam
    0xc20e000 – 0xc21fff7 com.apple.fxplugframework 1.2.3 (1.2.3) <033FEA79-E666-D319-5BD5-25A9A4331190> /Library/Frameworks/FxPlug.framework/Versions/A/FxPlug
    0xc232000 – 0xc236ff3 com.apple.audio.AudioIPCPlugIn 1.1.0 (1.1.0) <39CD9296-183C-5603-94A4-0A0EC327BA69> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
    0xc23b000 – 0xc240ffb com.apple.audio.AppleHDAHALPlugIn 1.7.4 (1.7.4a1) /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
    0xc245000 – 0xc245ffc com.apple.qmaster.swamp 3.5.1 (3.5.1) <391B264D-7A1E-0A17-D7D0-5970CDCA194F> /Library/Frameworks/Qmaster.framework/Versions/A/Qmaster
    0xc700000 – 0xc7feff7 com.apple.soundtrackpro.integration 3.0 (3.0) /Library/Application Support/ProApps/Bundles/Soundtrack Pro Integration.bundle/Contents/MacOS/Soundtrack Pro Integration
    0xcdc2000 – 0xd4f7fdf +com.borisfx.TextScrambler ??? (2.1) /Library/Application Support/Final Cut Pro System Support/Plugins/Text Scrambler.bundle/Contents/MacOS/Text Scrambler
    0xdf36000 – 0xe668fc7 +com.borisfx.Title3D ??? (2.1) /Library/Application Support/Final Cut Pro System Support/Plugins/Title 3D.bundle/Contents/MacOS/Title 3D
    0xf2aa000 – 0xf2ceff7 com.apple.AppleAVCIntraCodec 1.0 (16) <8A1A4CEE-1610-EECE-74DA-D2AF42825E6D> /Library/QuickTime/AppleAVCIntraCodec.component/Contents/MacOS/AppleAVCIntraCodec
    0xf2d9000 – 0xf2e4ff0 com.apple.fcp.TundraOutputUnit 1.3 (1.3) <0EC4D544-9A62-F164-0B39-F4097F006C27> /Applications/Final Cut Pro.app/Contents/Resources/TundraOutputUnit.bundle/Contents/MacOS/TundraOutputUnit
    0xf2ed000 – 0xf2f8ff7 com.apple.DVCPROHDVideoOutput 1.3.2 (1.3.2) <0BFC5A21-AD35-20C6-C495-9F91E7B49001> /Library/QuickTime/DVCPROHDVideoOutput.component/Contents/MacOS/DVCPROHDVideoOutput
    0xf500000 – 0xf655fec com.apple.Helium.HeliumRender 2.0.1 (225) <492BB54C-BB05-2E10-28AA-ACA28B3E1312> /Library/Application Support/ProApps/SharedA/Frameworks/Helium.framework/Versions/A/Frameworks/HeliumRender.framework/Versions/A/HeliumRender
    0xf6ab000 – 0xf6d3ff3 com.apple.mio.DAL.T3_VDC 22.0 (814) <98F14024-5661-1894-3F11-459B72DF8C1F> /System/Library/PrivateFrameworks/CoreMediaIOServicesPrivate.framework/Resources/VDC.plugin/Contents/MacOS/VDC
    0xf6e9000 – 0xf6f5fff com.apple.FinalCutPro.iChatTheaterPreview 1.0 (194) /Library/QuickTime/iChatTheaterPreview.component/Contents/MacOS/iChatTheaterPreview
    0xf800000 – 0xfa68ff2 com.apple.motion.filters 4.0.1 (578) <320323A1-D800-333B-F03A-9B2C02B796EB> /Library/Application Support/ProApps/SharedA/Plug-Ins/FxPlug/Filters.bundle/Contents/MacOS/Filters
    0xfb20000 – 0xfbbcff8 com.apple.procore.framework 4.0 (712) <09EE33B4-412C-FC25-5356-1DE47695BAA6> /Library/Application Support/ProApps/SharedA/Frameworks/ProCore.framework/Versions/A/ProCore
    0xfd00000 – 0xfd55fe2 com.apple.DVCPROHDAudio 1.3.2 (1.3.2) <6F4FE6F8-74E2-3901-2D11-8B9F0164F13A> /Library/Audio/Plug-Ins/HAL/DVCPROHDAudio.plugin/Contents/MacOS/DVCPROHDAudio
    0xfd74000 – 0xfdd9fe0 com.apple.DVCPROHDMuxer 1.3.2 (1.3.2) /Library/QuickTime/DVCPROHDMuxer.component/Contents/MacOS/DVCPROHDMuxer
    0xfdf3000 – 0xfe34fe3 com.apple.audio.SoundManager.Components 3.9.4 (3.9.4) /System/Library/Components/SoundManagerComponents.component/Contents/MacOS/SoundManagerComponents
    0xfe3b000 – 0xfef8fe2 com.apple.DesktopVideoOut 1.2.6 (1.2.6) /Library/QuickTime/DesktopVideoOut.component/Contents/MacOS/DesktopVideoOut
    0xff17000 – 0xff21ff7 com.apple.IOFWDVComponents 1.9.9 (1.9.9) <5B4E7BD7-EF5A-2F5C-DF8E-3D4A7B59F779> /System/Library/Components/IOFWDVComponents.component/Contents/MacOS/IOFWDVComponents
    0xff3b000 – 0xff72ff7 com.apple.CompressorKit 3.5.1 (3.5.1) /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/CompressorKit.framework/CompressorKit
    0xffa1000 – 0xffabff7 com.apple.compressor.MediaServerAPI 3.5.1 (3.5.1) <04EB0E88-B3E3-370B-5AD5-2C091CFB01D5> /Library/Frameworks/MediaServerAPI.framework/Versions/A/MediaServerAPI
    0xffb8000 – 0xffc3fff com.apple.compressor.StompUtil 3.5.1 (3.5.1) <05D5756A-8FB6-02AD-31E3-2A940181FCAE> /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/StompUtil.framework/Versions/A/StompUtil
    0xffd2000 – 0xffddfff com.apple.qmaster.SwampUtil 3.5.1 (3.5.1) <54C5ACDA-90D4-D99F-A20E-6A8CF4A4AE9C> /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampUtil.framework/Versions/A/SwampUtil
    0xffea000 – 0xfff0fff com.apple.compressor.FilterUI 3.5.1 (3.5.1) /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/FilterUI.framework/Versions/A/FilterUI
    0x10000000 – 0x10060fef com.apple.proapps.AudioMixEngine 2.0 (68) /Applications/Final Cut Pro.app/Contents/Frameworks/AudioMixEngine.framework/Versions/A/AudioMixEngine
    0x20091000 – 0x207c1fef +com.borisfx.TitleCrawl ??? (2.1) /Library/Application Support/Final Cut Pro System Support/Plugins/Title Crawl.bundle/Contents/MacOS/Title Crawl
    0x211fe000 – 0x21934ff7 +com.borisfx.VectorShape ??? (2.1) /Library/Application Support/Final Cut Pro System Support/Plugins/Vector Shape.bundle/Contents/MacOS/Vector Shape
    0x229f2000 – 0x22b4cff7 com.apple.AECore 3.5.1 (3.5.1) <3835AD4E-B21E-FF42-C36C-60CD2B644D84> /Library/Frameworks/AECore.framework/Versions/A/AECore
    0x22be4000 – 0x22c86fef com.apple.compressor.StompUI 3.5.1 (3.5.1) <14E4B46B-ABAD-F55C-C713-98EBD3629316> /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/StompUI.framework/Versions/A/StompUI
    0x22ce4000 – 0x22d18fff com.apple.qmaster.SwampCore 3.5.1 (3.5.1) <0C856CEA-BE8A-9529-87FE-BD62177D428E> /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampCore.framework/Versions/A/SwampCore
    0x22d43000 – 0x22d4cfff com.apple.qmaster.SwampService 3.5.1 (3.5.1) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampService.framework/Versions/A/SwampService
    0x22d5c000 – 0x22d66fff com.apple.qmaster.Status 3.5.1 (3.5.1) <63C2745D-BE37-AD9F-632A-9FEBDC3C9799> /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/Status.framework/Versions/A/Status
    0x31e83000 – 0x31f6bfe3 com.apple.compressor.StompTypes 3.5.1 (3.5.1) <97A4B508-4B8E-B76B-096E-CCE5E7DA3244> /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/StompTypes.framework/Versions/A/StompTypes
    0x31ff4000 – 0x320bbfe3 com.apple.qmaster.SwampTypes 3.5.1 (3.5.1) <584FD0C4-EA96-635E-4FD6-71C724DD4FC6> /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampTypes.framework/Versions/A/SwampTypes
    0x32148000 – 0x321bcff8 com.apple.qmaster.do 3.5.1 (3.5.1) <2D0FDF8D-E2A7-C6FC-A768-585E2C67D3B9> /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/DistributedObjects.framework/Versions/A/DistributedObjects
    0x32225000 – 0x32230fff com.apple.qmaster.RequestProcessing 3.5.1 (3.5.1) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/RequestProcessing.framework/Versions/A/RequestProcessing
    0x32244000 – 0x32257ffb com.apple.qmaster.ServiceControl 3.5.1 (3.5.1) <61D988F2-6DFF-D459-AA41-27F5D687A8DB> /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/ServiceControl.framework/Versions/A/ServiceControl
    0x32270000 – 0x322ddff3 com.apple.qmaster.ContentControl 3.5.1 (3.5.1) <81871BE6-92C0-1D93-A491-4DE3EA583DF4> /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/ContentControl.framework/Versions/A/ContentControl
    0x32325000 – 0x323eafff com.apple.qmaster.JobControl 3.5.1 (3.5.1) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/JobControl.framework/Versions/A/JobControl
    0x32473000 – 0x3247efff com.apple.qmaster.ClusterManager 3.5.1 (3.5.1) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/ClusterManager.framework/Versions/A/ClusterManager
    0x3248d000 – 0x324b7ff7 com.apple.qmaster.SwampUI 3.5.1 (3.5.1) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampUI.framework/Versions/A/SwampUI
    0x324dc000 – 0x324e7fff com.apple.qmaster.SwampExecutor 3.5.1 (3.5.1) <5C54E16E-BBCF-1FBC-61DB-3E30C3B25A2E> /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampExecutor.framework/Versions/A/SwampExecutor
    0x324fb000 – 0x32504fff com.apple.dsppublishing 1.0.0 (115) /Library/Frameworks/DSPPublishing.framework/Versions/A/DSPPublishing
    0x32512000 – 0x3254afff com.apple.compressor.ImageProcessing 3.5.1 (3.5.1) <6169DAEC-9D5E-4FB1-13AE-EF5015042A07> /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/ImageProcessing.framework/Versions/A/ImageProcessing
    0x32573000 – 0x32712feb com.apple.compressor.transcoding 3.5.1 (3.5.1) <00EF53A5-1152-2A2E-2387-50D8AD8E01CE> /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/Transcoding.framework/Versions/A/Transcoding
    0x32838000 – 0x32861fef com.apple.audio.CoreAudioKit 1.6 (1.6) /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
    0x32872000 – 0x32877fe7 com.apple.H264Encoder 1.0 (21) <89E6BDC0-2281-39EA-58CF-4DF45397B61D> /Library/Application Support/ProApps/SharedA/Frameworks/H264Encoder.framework/Versions/A/H264Encoder
    0x32bc2000 – 0x32bc7ff1 com.apple.finalcutpro.dvcprohdfrcplugin 1.2.0 (16) /Applications/Final Cut Pro.app/Contents/PlugIns/DVCPROHD Frame Rate Converter.bundle/Contents/MacOS/DVCPROHD Frame Rate Converter
    0x3b7c8000 – 0x3b7ccff7 com.apple.qldisplay.Generic 2.0 (327.0) <586067E7-4D6A-3782-B07E-B139AFCACAE6> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/Resources/DisplayBundles/Generic.qldisplay/Contents/MacOS/Generic
    0x3e67a000 – 0x3e86bfd2 +net.telestream.wmv.import 2.3.0.14 (2.3.0.14) /Library/QuickTime/Flip4Mac WMV Import.component/Contents/MacOS/Flip4Mac WMV Import
    0x3e8a1000 – 0x3ea61ff2 +net.telestream.wmv.advanced 2.3.0.14 (2.3.0.14) <125E7162-2457-453D-9707-5902DEB4D32E> /Library/QuickTime/Flip4Mac WMV Advanced.component/Contents/MacOS/Flip4Mac WMV Advanced
    0x3eaa6000 – 0x3eb1ffef com.apple.AppleVAH264HW.component 2.0 (1.0) /System/Library/QuickTime/AppleVAH264HW.component/Contents/MacOS/AppleVAH264HW
    0x70000000 – 0x700cbfe7 com.apple.audio.units.Components 1.6 (1.6) /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
    0x8f613000 – 0x8fa52ff3 com.apple.GeForce8xxxGLDriver 1.6.2 (6.0.2) /System/Library/Extensions/GeForce8xxxGLDriver.bundle/Contents/MacOS/GeForce8xxxGLDriver
    0x8fe00000 – 0x8fe4162b dyld 132.1 (???) <211AF0DD-42D9-79C8-BB6A-1F4BEEF4B4AB> /usr/lib/dyld
    0x90003000 – 0x9010cfe7 com.apple.CoreAUC 4.10.0 (4.10.0) <34606DCE-1257-8FB9-E633-AC56DD263EAB> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
    0x908f3000 – 0x90936ff7 com.apple.NavigationServices 3.5.3 (181) <28CDD978-030E-7D4A-5334-874A8EBE6C29> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
    0x9097e000 – 0x909f7ff7 com.apple.PDFKit 2.5 (2.5) <58603BDB-337F-FBE3-EB11-7C31CF261995> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
    0x909f8000 – 0x90a0dff7 com.apple.iChat.InstantMessage 5.0 (742) /System/Library/Frameworks/InstantMessage.framework/Versions/A/InstantMessage
    0x90a13000 – 0x90a16ff7 libCoreVMClient.dylib ??? (???) <16BB2178-B32D-E57E-F1E4-D177F7754232> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
    0x90a17000 – 0x90ae1fef com.apple.CoreServices.OSServices 352 (352) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
    0x90ae2000 – 0x90b7afe7 edu.mit.Kerberos 6.5.8 (6.5.8) /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
    0x90b7b000 – 0x90b9fff7 libJPEG.dylib ??? (???) <265DBF67-994E-E320-4CB1-9C3DE792C3B2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x90ba0000 – 0x90bd6fff libtidy.A.dylib ??? (???) /usr/lib/libtidy.A.dylib
    0x90bd7000 – 0x90efafef com.apple.HIToolbox 1.6.0 (???) <6F95AF67-678A-D8BC-FFC2-029C9AA2F44A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
    0x90efb000 – 0x90fccff3 ColorSyncDeprecated.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
    0x9102b000 – 0x9105bff7 com.apple.MeshKit 1.0 (49.0) <435718C1-ED40-6BCC-F0D8-67FA05CFFF1E> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/MeshKit
    0x91173000 – 0x91a50ff7 com.apple.AppKit 6.6.1 (1038.2) <27C304F6-0045-160B-7591-E57ECF19BDDB> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x91a51000 – 0x91a61ff7 libsasl2.2.dylib ??? (???) /usr/lib/libsasl2.2.dylib
    0x91a6a000 – 0x91b48fff com.apple.QuickTimeMPEG4.component 7.6.3 (1584) <75DC17F7-B0A5-2D13-C8CA-569A8C3BAAD3> /System/Library/QuickTime/QuickTimeMPEG4.component/Contents/MacOS/QuickTimeMPEG4
    0x91b49000 – 0x91b5efff com.apple.ImageCapture 6.0 (6.0) <3F31833A-38A9-444E-02B7-17619CA6F2A0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
    0x91b5f000 – 0x91b6fff7 com.apple.DSObjCWrappers.Framework 10.6 (134) <81A0B409-3906-A98F-CA9B-A49E75007495> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers
    0x91b8e000 – 0x91d6efff com.apple.imageKit 2.0 (1.0) /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
    0x91d6f000 – 0x91d87ff3 com.apple.ScriptingBridge 1.1 (???) <027C057F-7085-8A3E-9FEB-2FCFFD4CB2E2> /System/Library/Frameworks/ScriptingBridge.framework/Versions/A/ScriptingBridge
    0x91d88000 – 0x91e37ff3 com.apple.ink.framework 1.3 (104) <8526D880-D367-3EF9-DBFD-9A6AB240F57A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
    0x91e38000 – 0x91e3fff7 com.apple.agl 3.0.12 (AGL-3.0.12) <6BF89127-C18C-27A9-F94A-981836A822FE> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
    0x91e40000 – 0x91fc2fe7 libicucore.A.dylib ??? (???) /usr/lib/libicucore.A.dylib
    0x91fc3000 – 0x91fe3fe7 libresolv.9.dylib ??? (???) /usr/lib/libresolv.9.dylib
    0x91fe4000 – 0x920d8fe7 libiconv.2.dylib ??? (???) <0C578460-3929-29DD-585A-DB1E0C977425> /usr/lib/libiconv.2.dylib
    0x920d9000 – 0x92148ff7 libvMisc.dylib ??? (???) <59243A8C-2B98-3E71-8032-884D4853E79F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
    0x92149000 – 0x92199ff7 com.apple.framework.familycontrols 2.0 (2.0) <50617342-E578-4C1C-938A-19A37ECA91CA> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
    0x9219a000 – 0x921a4ffb com.apple.speech.recognition.framework 3.10.10 (3.10.10) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
    0x921a5000 – 0x92242ff3 com.apple.LaunchServices 360.3 (360.3) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
    0x92243000 – 0x92243ff7 com.apple.vecLib 3.5 (vecLib 3.5) <17BEEF92-DF30-CD52-FD65-0B7B43B93617> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
    0x92244000 – 0x9225cff7 com.apple.CFOpenDirectory 10.6 (10.6) <1537FB4F-C112-5D12-1E5D-3B1002A4038F> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
    0x9225d000 – 0x92287ff7 com.apple.shortcut 1.1 (1.1) /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
    0x92288000 – 0x922c2fe7 libFontRegistry.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
    0x922c3000 – 0x93251ff7 com.apple.QuickTimeComponents.component 7.6.3 (1584) /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
    0x93252000 – 0x93283ff7 libGLImage.dylib ??? (???) <0FB347C7-A579-4E51-4733-39AB28064554> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
    0x932ae000 – 0x93367fe7 libsqlite3.dylib ??? (???) <16CEF8E8-8C9A-94CD-EF5D-05477844C005> /usr/lib/libsqlite3.dylib
    0x93368000 – 0x93442fe7 com.apple.DiscRecording 5.0 (5000.4.6) <8471B33F-5B5A-13EA-04B4-41882AE63C7D> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
    0x93443000 – 0x934f2fe3 com.apple.QuickTimeImporters.component 7.6.3 (1584) <34BF4FBA-BFCD-9A47-4BA9-E2B155C5C881> /System/Library/QuickTime/QuickTimeImporters.component/Contents/MacOS/QuickTimeImporters
    0x934f3000 – 0x934f3ff7 com.apple.CoreServices 44 (44) /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
    0x934f4000 – 0x93512ff7 com.apple.iChat.IMFoundation 5.0 (742) <4681711D-5AC2-8C23-4B77-081B97E399F9> /System/Library/Frameworks/IMCore.framework/Frameworks/IMFoundation.framework/Versions/A/IMFoundation
    0x93513000 – 0x93514ff7 com.apple.TrustEvaluationAgent 1.0 (1) <71E2DA16-83EC-6056-FFEE-862A04B5599F> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
    0x93515000 – 0x9351fff7 com.apple.bsd.ServiceManagement 1.0 (1.0) /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
    0x93520000 – 0x93522ff7 libRadiance.dylib ??? (???) <0E03CF64-0931-7B9A-F617-4387B809D6D8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
    0x93556000 – 0x935d8ffb SecurityFoundation ??? (???) <29C27E0E-B2B3-BF6B-B1F8-5783B8B01535> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
    0x935d9000 – 0x93619fe7 com.apple.IMCore 5.0 (742) <8BFC7809-7D60-7BFF-792C-A6BC8A288548> /System/Library/Frameworks/IMCore.framework/Versions/A/IMCore
    0x9361a000 – 0x936b6fe7 com.apple.ApplicationServices.ATS 4.0 (???) <81700C90-2614-F7E2-CC6A-B01C24A2BD75> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
    0x936b7000 – 0x936c8ff7 com.apple.LangAnalysis 1.6.5 (1.6.5) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
    0x936c9000 – 0x936d0fff com.apple.print.framework.Print 6.0 (237) <7A06B15C-B835-096E-7D96-C2FE8F0D21E1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
    0x936d1000 – 0x937f9fe7 com.apple.CoreData 102 (246) /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x937fa000 – 0x937ffff7 com.apple.OpenDirectory 10.6 (10.6) <92582807-E8F3-3DD9-EB42-4195CFB754A1> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
    0x93800000 – 0x939fdfeb com.apple.AddressBook.framework 5.0 (862) /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
    0x939fe000 – 0x93bbafef com.apple.ImageIO.framework 3.0.0 (3.0.0) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
    0x93bbb000 – 0x93c32feb com.apple.backup.framework 1.1 (1.0) <73C642BD-A0C5-7D45-79FA-0AA6D96226C0> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
    0x93c7a000 – 0x93c7aff7 com.apple.quartzframework 1.5 (1.5) /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
    0x93c7b000 – 0x93cbcff7 libRIP.A.dylib ??? (???) <6DB158C6-A84D-98C9-1D48-868A3DB17D09> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
    0x93cf6000 – 0x93cfdff7 com.apple.iChat.IMUtils 5.0 (742) <8AA5F7A8-73D3-1F0D-5ED1-F3E16B7C8D04> /System/Library/Frameworks/IMCore.framework/Frameworks/IMUtils.framework/Versions/A/IMUtils
    0x93cfe000 – 0x93d5efe7 com.apple.CoreText 3.0.0 (???) <8F4FCAE2-8E6F-F0DE-A6AA-15D0228B7F13> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
    0x93d5f000 – 0x93d73ffb com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <57DD5458-4F24-DA7D-0927-C3321A65D743> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x93d74000 – 0x93e4efff com.apple.DesktopServices 1.5.1 (1.5.1) /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
    0x93e9d000 – 0x94014fef com.apple.CoreFoundation 6.6 (550) <193E33D6-2E92-3452-773B-60A1A9CCC573> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x94015000 – 0x94027ff7 com.apple.MultitouchSupport.framework 200.20 (200.20) <1D7EE15B-ADDD-1F57-F1FB-FB5252910D5A> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
    0x94028000 – 0x940d7fef com.apple.ColorSync 4.6.0 (4.6.0) <66ABAE86-B0EC-D641-913D-08ACA965F9FA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
    0x940d8000 – 0x94130fe7 com.apple.datadetectorscore 2.0 (80.7) /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
    0x94131000 – 0x94238fe3 com.apple.DiskImagesFramework 10.6 (281) /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
    0x94239000 – 0x94464ff3 com.apple.QuartzComposer 4.0 (156.6) /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
    0x94465000 – 0x94472ff7 com.apple.opengl 1.6.3 (1.6.3) <59D86286-B46F-B0E4-68F8-E5CDCADE393E> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x94473000 – 0x94475ff7 com.apple.securityhi 4.0 (36638) <962C66FB-5BE9-634E-0810-036CB340C059> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
    0x944f1000 – 0x944f7fff com.apple.CommonPanels 1.2.4 (91) <2438AF5D-067B-B9FD-1248-2C9987F360BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
    0x944f8000 – 0x94549ff7 com.apple.HIServices 1.8.0 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
    0x9454a000 – 0x9454dfe7 libmathCommon.A.dylib ??? (???) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
    0x9454e000 – 0x94847fef com.apple.QuickTime 7.6.3 (1584) <687233E1-F428-5224-08D5-5874BEA2300D> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
    0x94848000 – 0x94852ff7 com.apple.HelpData 2.0.3 (33) /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
    0x94853000 – 0x94960ff7 com.apple.MediaToolbox 0.420.17 (420.17) /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
    0x94961000 – 0x9496eff7 com.apple.NetFS 3.2 (3.2) /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
    0x9496f000 – 0x949effeb com.apple.SearchKit 1.3.0 (1.3.0) <9E18AEA5-F4B4-8BE5-EEA9-818FC4F46FD9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
    0x94a99000 – 0x94acdff7 libcups.2.dylib ??? (???) <9078BA07-DEE1-6597-D15D-7BE3A20CB5A0> /usr/lib/libcups.2.dylib
    0x94ace000 – 0x94c72feb libSystem.B.dylib ??? (???) /usr/lib/libSystem.B.dylib
    0x94c73000 – 0x94c9bff7 libxslt.1.dylib ??? (???) <769EF4B2-C1AD-73D5-AAAD-1564DAEA77AF> /usr/lib/libxslt.1.dylib
    0x94cc2000 – 0x94dc4fef com.apple.MeshKitIO 1.0 (49.0) /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitIO.framework/Versions/A/MeshKitIO
    0x94e34000 – 0x94e7aff7 libauto.dylib ??? (???) /usr/lib/libauto.dylib
    0x94f2a000 – 0x94f2eff7 libGIF.dylib ??? (???) <51848EBF-27D4-0F85-C22A-D1AE10D328F3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
    0x94f2f000 – 0x94f4efe7 com.apple.opencl 11 (11) <372A42E7-FB10-B74D-E1A0-980E94D07021> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
    0x94f4f000 – 0x94f8bfff com.apple.CoreMediaIOServices 101.0 (715) /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versions/A/CoreMediaIOServices
    0x94f8c000 – 0x94f98ff7 libkxld.dylib ??? (???) <152C8DBB-0149-5827-3240-E57CA85CFE5F> /usr/lib/system/libkxld.dylib
    0x94fa1000 – 0x94fcbff7 com.apple.framework.Admin 4.0 (4.0) <4A434473-A6C1-3F40-2928-16CFF1222FA1> /System/Library/PrivateFrameworks/Admin.framework/Versions/A/Admin
    0x94fcc000 – 0x95073fe7 com.apple.CFNetwork 454.4 (454.4) <7C563385-9893-3B48-8607-5BC81DA2C4CF> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
    0x95074000 – 0x950b3ff7 com.apple.ImageCaptureCore 1.0 (1.0) /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
    0x950b4000 – 0x950d2ff7 com.apple.CoreVideo 1.6.0 (43.0) <3A853574-DD9E-08D8-FD2C-6221B55C3E08> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x950d3000 – 0x95581fe7 com.apple.VideoToolbox 0.420.17 (420.17) /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
    0x95582000 – 0x955a1fe3 libexpat.1.dylib ??? (???) <82E6F83F-9667-2E39-1D9D-4A49C642527D> /usr/lib/libexpat.1.dylib
    0x955a2000 – 0x955bdff7 libPng.dylib ??? (???) <38DD4AA1-0643-85A0-F2F5-EE9269729975> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
    0x955be000 – 0x955f5ff7 com.apple.CoreMedia 0.420.17 (420.17) /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/CoreMedia
    0x95607000 – 0x95675ff7 com.apple.ISSupport 1.9.1 (49) /System/Library/PrivateFrameworks/ISSupport.framework/Versions/A/ISSupport
    0x95686000 – 0x956c6ff3 com.apple.securityinterface 4.0 (36981) /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
    0x956ce000 – 0x95712fe7 com.apple.Metadata 10.6.0 (507.1) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
    0x95713000 – 0x958a1fff com.apple.JavaScriptCore 6531 (6531.5) /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
    0x958a2000 – 0x958a2ff7 com.apple.ApplicationServices 38 (38) <8012B504-3D83-BFBB-DA65-065E061CFE03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
    0x958a3000 – 0x958a3ff7 com.apple.Carbon 150 (152) <608A04AB-F35D-D2EB-6629-16B88FB32074> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x958a4000 – 0x958f4fe7 libGLU.dylib ??? (???) <55A69DCE-1237-341E-F239-CDFE1F5B19BB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
    0x959a4000 – 0x95a4cff7 com.apple.QD 3.31 (???) <40FCAC85-4E4F-2290-90D4-F66D550ADFDC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
    0x95a4d000 – 0x95a4fff7 com.apple.QuickTimeH264.component 7.6.3 (1584) /System/Library/QuickTime/QuickTimeH264.component/Contents/MacOS/QuickTimeH264
    0x95a50000 – 0x95b42ff7 libcrypto.0.9.8.dylib ??? (???) <792B8722-3091-5E9F-E25F-67499CFE0599> /usr/lib/libcrypto.0.9.8.dylib
    0x95b43000 – 0x95b43ff7 liblangid.dylib ??? (???) /usr/lib/liblangid.dylib
    0x95b44000 – 0x95f5aff7 libBLAS.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
    0x95f61000 – 0x95f61ff7 com.apple.Accelerate.vecLib 3.5 (vecLib 3.5) <3E039E14-2A15-56CC-0074-EE59F9FBB913> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
    0x95f62000 – 0x95f9bfe7 com.apple.bom 10.0 (164) /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
    0x95f9c000 – 0x9600aff7 com.apple.QuickLookUIFramework 2.0 (327.0) <86D7E331-4C25-D360-7316-BA32192686D7> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
    0x9600b000 – 0x9600cff7 com.apple.audio.units.AudioUnit 1.6 (1.6) <68180B96-381C-A09D-5576-606A134FD953> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x9600d000 – 0x96011ff7 IOSurface ??? (???) /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
    0x96112000 – 0x96182ffb com.apple.AppleVAFramework 4.6.2 (4.6.2) <25381B2A-89A6-0CEB-C159-DFF70C76B881> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
    0x96183000 – 0x96964497 com.apple.CoreGraphics 1.535.5 (???) <0B93D29C-D957-AD00-10F3-94112D75D6D9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x96965000 – 0x9699dff7 com.apple.LDAPFramework 2.0 (120.1) <8C7F3F42-6A4D-D37A-4232-685D44E8769E> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
    0x9699e000 – 0x96a7bff7 com.apple.vImage 4.0 (4.0) <64597E4B-F144-DBB3-F428-0EC3D9A1219E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
    0x96bd8000 – 0x96e48ffb com.apple.Foundation 6.6 (751) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x96e49000 – 0x97168fe7 com.apple.CoreServices.CarbonCore 859.1 (859.1) <2E72AF56-4BE6-294A-7372-19C360688B8B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/V
  • Peter Corbett
    December 10, 2009 at 7:29 am
    [Scott Dedoes] “I am having similar problems trying to finalize a video project and apparently am not tech savvy enough to figure this out. Final Cut pro started crashing during the editing of a project and for a while I was able to get it to work by first opening up an older project first. Now I cannot get it to open at all. I have tried reinstalling and deleting the preferences. If anyone could help, I would be eternally grateful as I am going insane here.”
    Hi Scott,
    I’m as new to FCP as you. I got around it by creating a new project, then copying the bins and sequences to the new job. I also trashed the preferences and started again. It is a pain I admit.
    Peter
    Peter Corbett
    Powerhouse Productions
    http://www.php.com.au
  • Scott Dedoes
    December 11, 2009 at 12:37 am
    Hi Peter,
    Thank you so much for the quick reply. Because I am so new to Final Cut, I am unaware how to copy the bins and sequences to a new project. I cannot get the project that I am working on to open at all. I am able to start new projects, work on old projects etc, but it will not open the problem project file. This happened after I added some still pictures to the file. I only have the project file saved on my hard drive and do not see individual sequences or bins anywhere. The only files I have are Audio Render files, Autosave Vault, Capture Scratch, Render files, Thumbnail Cache Files, or Waveform Cache files.
    I have tried trashing preferences as well, with no luck.
    Thanks in advance for any future help you might be able to offer.
    Scott
