Activity Forums Apple Final Cut Pro Legacy final cut verses avid express
  • final cut verses avid express
    Posted by Stevejr on May 16, 2005 at 4:08 pm
    hi all,
    question, I am most likey going to be getting a final cut pro system. I have looked also at avid express. I have tested both systems and feel that as of right now final cut pro is the better system. Can any of you please give me reasons why final cut pro is so good. It seems to render faster then avid express pro. I would really like to here from those who have edited on both systems.
    thanks,
    wildmangoose
    Sean Lander replied 21 years, 4 months ago 4 Members · 3 Replies
  • Torv Carlsen
    May 16, 2005 at 6:07 pm
    HI Wildman.
    In a nutshell, FCP’s advantage over Avid Xpress is it’s scalability. That is you can add various third party hardware like the AJA i/o (uncompressed 10 bit SDI, component, etc.), Kona2 (uncompressed SDI and HD) or any one of the Blackmagic Design cards and increase FCP resolution indenpendent platform to edit any type of video you see fit to edit, provided of course you have a hard disk array capable of the demands of high end video. XPress DV is limited to DV only, no scalability to edit or output in anything but DV, unless you buy Avid’s XPress Pro with the Mojo box which at $3495 will set you back as much FCP & AJA’s Kona2 card but not give you HD or anything approaching the quality of video i/o that AJA is known for. That said however, Avid’s Xpress DV’s projects are easily transported to the higher end Avid systems like a Symphony for more advanced finishing. A knock on FCP is it’s project management, an asset the Avids are well known for, although frankly I have never had a problem with project management in FCP though others have and continue to gripe about that, but they predominantly come from years as Avid editors so they are used to a certain workflow. There are many other differences between the two projects, but all in all, FCP is far more versatile than the Avid product. If you’re predisposition is Avid however because of your experience, that might be a better choice for you. It all depends on what your needs are.
    Good luck.
    Torv
  • Ryan Cornish
    May 16, 2005 at 6:12 pm
    I have taught the Express Pro system and use FinalCut at home. I would say they both have aspects I like. FinalCut however has made it easy and more affordable to upgrade in the future. Plus it’s a Mac program. As far as ease of use I really do think they both work well. Hope that helps.
  • Sean Lander
    May 18, 2005 at 9:13 am
    With the Avid you are LOCKED IN to DV.
    With Final Cut Pro you can do anything from 320-240 to High Def.
    The interface is by far more intuitive and the suite of products that come with it way more powerful. (FCP Studio)
    Final Cut Pro is the most popular editing software in the world by a long way.
    You will be future proofing yourself. The next crop of editors coming out from film schools in the next few years
    won’t even know what an Avid is. (slight exaggeration here but it I am seeing strong evidence of this already)
