Activity Forums Apple Final Cut Pro Legacy Final Cut Unexpected Quit
  • Final Cut Unexpected Quit
    Posted by Chris Anderson on September 19, 2008 at 5:02 pm
    The system is only a few months old and this is the first big project on it. I’m running Final Cut Studio 6.0.4
    The sequence is a 20min HDV sequence set to render in ProRes. Everything was working fine for the first few weeks but I started getting random “Unexpected Quit” in Final Cut. I would have to use the autosave vault to restore the project since the original project would not retain the last manual save I did.
    Now I can’t even export a quicktime (reference or movie) without FCP quitting. I do have success at times if I break the sequence up into to sections but this hasn’t narrowed down a bad section since it’s still random.
    It will play back fine and thanks to the Kona3 I was able to at least burn an rough cut dvd.
    The media is on a 4drive eSATA raid (0) using a CalDigit Fasta 4e card.
    So far I:
    Trashed the preferences
    Yesterday I updated to 10.5.5 hoping that would help.
    Checked the ram configuration
    I suspect it has something to do with ProRes
    I have a DVCPRO HD project on it that exports fine however it was only a few minutes.
    Any ideas?
    Chris
    Chris Anderson replied 17 years, 11 months ago 1 Member · 2 Replies
  • Chris Anderson
    September 19, 2008 at 6:05 pm
    An Update!
    I was just able to export a Quicktime Movie (self contained) using the AJA 1080 60i ProRes instead of current settings.
  • Chris Anderson
    September 22, 2008 at 2:02 pm
    Well that didn’t last long.
    I’m still getting the quits about half way thru an export.
    Any ideas?
