Activity Forums Apple Final Cut Pro Legacy Final Cut to YouTube
  • Final Cut to YouTube
    Posted by Fernando Bobadilla on December 28, 2012 at 11:11 pm
    Hello,
    I shot my footage with a DSLR at 30fps. I’m wondering how I can export my project and have it ready to upload to YouTube..
    I know some people export as a quicktime movie and use compressor, and others use quicktime conversion and tinker with the bit rates – I want to know what’s best to get the best quality out of my project.
    Fernando
    Chris Schaap replied 13 years, 8 months ago 5 Members · 4 Replies
  • David Roth weiss
    December 29, 2012 at 6:26 am
    There’s no easy answer to your question because compression is a learned combination of both art and science. However, Compressor is the serious users choice, plus it comes with loads of presets, including a few clearly labeled as YouTube.
    If you’re new, use the presets in Compressor.
    David Roth Weiss
    ProMax Systems
    Burbank
    DRW@ProMax.com
    Sales | Integration | Support
    David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
  • Rafael Amador
    December 29, 2012 at 1:28 pm
    As David said, start by a preset for YouTube.
    For data rate and audio sampling, read YouTube recommendations.
    Set always “Keyframes: AUTO”, and make Multipass.
    For a better downscaling, check “Frame Control ON”, and Downscaling Fiter> BEST.
    rafael
    http://www.nagavideo.com
  • Sascha Engel
    January 3, 2013 at 10:33 am
    Here is my way, which seems to look very good on YT:
    Export first QT Movie to make a master in original HD quality.
    Going directly from TL to Compressor takes way longer encoding time.
    The final Master QT Export, you open in Compressor.
    Drop a QT 7 compatibel H.264 preset from the Web/Download Preset Folder: The preset H.264 LAN.
    The adjust following parameters:
    – Encoder Tab: Video set to Multi Pass (if you don’t have time, single pass is fine as well), change data rate to 5000 kbits/sec, Audio 224 Kb/sec
    – Geometry Tab: Set frame size to 100% of Source for HD on YT
    There go go. Usually those settings look great as HD on YT.
    Check out this sample of mine in those settings:
    https://www.youtube.com/watch?v=3C0HQXQ0dMA
    watch it in full HD!
    Greetings,
    Sascha
  • Chris Schaap
    January 3, 2013 at 7:21 pm
    Do you also notice that when you upload your export to youtube the final version on YouTube is darker then the original?
