Activity Forums Apple Final Cut Pro Legacy FINAL CUT to DVD – jumpy playback
  • FINAL CUT to DVD – jumpy playback
    Posted by Lawrence Vaughan
    on October 20, 2007 at 4:45 pm
    Hi Everyone, I have a 2.4 dual core imac (3 gig of ram) I am trying to export a movie I have made in Final Cut Pro version 5.1 – which is the best setting to use for standard DVD playback (which will be burnt in idvd), I have tried DVpal, DV pal 24fps & HDV – all of them either give me jumpy playback or, some real nasty lines when something is moving on screen.
    Also – what is the best setting to export something for the web, i.e. – youtube?
    Any help is greatly appreciated.
    Lawrence
    Lawrence Vaughan
    replied 18 years, 11 months ago
    3 Members · 4 Replies
  • Colin Mcquillan
    October 20, 2007 at 5:17 pm
    As far as jumpy playback and ugly lines go, I think you may have your fields reversed. Are you monitoring with an external CRT? and are the nasty lines you talk about what you see on your computer monitor or on a TV from the DVD after it is burnt? If it on a TV then you have your fields set wrong somewhere, If its on your computer monitor after export from FCP,, then this is normal. Make sure your field dominance in your iDVD project, Final Cut export, and Final Cut Timeline are correct.
    I always use compressor to export from FCP to make DVD’s , and use the “best 90min” setting if disk space allows. I use DVDSP to author DVD’s though,, not sure about iDVD.
    Do a search on in the FCP forum on DVD export settings, I’ve seen this topic come up a bunch of times over the passed month or 2.
    cheers,
    Colin McQuillan
    Vancouver BC
  • Lawrence Vaughan
    October 21, 2007 at 7:25 am
    Thanks Colin!
    The lines are after I export and watch the DVD on a TV. I don’t use another monitor, just my mac one. The fact that you have seen this topic crop up on here before is slightly comforting, at least I know it’s not just me who is having these problems.
    I’ll do a search and have a look for a solution, which really – is what I should have done in the first place.
    Thanks.
  • Mark Palmos
    October 23, 2007 at 10:27 pm
    i think colin is right about the field thing.
    in pal, DV has a different field order from SD or DVD MPEG-2, and for some reason both Premier and FCP do not correct this automatically. Make sure you are rending with Upper field first.
    If this does not work, then apply the field switching filter (not sure exactly what its called) and advance the field by +1 on each clip in the timeline and re-render. That should sort it.
    mark.
  • Lawrence Vaughan
    October 24, 2007 at 9:59 pm
    cool. ill give it a whirl, hopefully it will fix it.
    thanks.
