Activity › Forums › Broadcasting › Final Cut to DVCPRO-NTSC question
  • Final Cut to DVCPRO-NTSC question
    Posted by Michael Brodner on April 27, 2009 at 4:15 pm
    Update on my first journey into submitting commercials to the broadcast world
    I finished editing a 30 second commercial for a friends restaurant and I’m in the process of compressing it for Time Warner. The gentleman I have been in contact with says the best way for me to deliver the spot is to export it as DVCPRO-NTSC.
    I tried export > quicktime movie > and then chose the DVCPRO – NTSC preset right from my Final Cut timeline and the result was very “jaggy” especially in the text. I mentioned this to the guy and he said to keep in mind that NTSC looks worse on a computer than on TV, especially text that has any motion right to left. He said Time Warner doesn’t work in HD at all and that at some point it’ll be converted to SD anyways.
    So what should I do? My sequence preset is set up for 1080i HDV. I shot the commercial with a Sony HDR FX1 and it looks great in Final Cut. The NTSC export, as I said before, doesn’t look as great. Do I export the spot as a self contained quicktime file and then compress it using quicktime pro or visual hub to DVCPRO-NTSC…OR… just give him the DVCPRO-NTSC export right from Final Cut?
    Devin Crane replied 17 years, 5 months ago 3 Members · 5 Replies
  • Michael Brodner
    April 27, 2009 at 5:07 pm
    Ah no I do not have an AJA card. Actually, I have no clue what that is, LOL. I pretty much have been shooting video/wedding stuff on my own. I’m at the “serious hobbyist” / higher-end amateur level if you will.
    BUT…I do have After Effects and know my way around it pretty well. I actually used the suretarget plugin from videocopilot.net for my text layers and motion graphics. Your After Effects approach sounds like it would work well with my workflow. Any ideas on what kind of file size I can expect in the end?
  • Mark Suszko
    April 27, 2009 at 5:17 pm
    Did they ask for it on DVCpro tape? If so, considering you seem to not have an i/o box of any sort, go to a post house and just pay for them to play your best quality file of it out to tape for you. Or you cna rent a DVCpro deck with firewire and play into it as if it was your home camvcorder.
    Did they say DVCpro25 or DCVpro50, the distinction is important.
  • Michael Brodner
    April 27, 2009 at 5:31 pm
    Well no, not exactly. It’s an option. But they also said I could drop the file onto a flash card or even send it through Sendspace.com, which is what I initially did. The only problem with Sendspace.com is that it only allows you 300mb to send. If I had to, I could drop the file off at the station. Here’s the exact email I got from him. All he said was DVCPRO-NTSC. Said that a quicktime would be fine
    Heres what he wrote:
    “A few things to consider:
    1) We don’t work in HD at all. Master Control can’t accept HD.
    2) It’s going to be converted to SD at some point, and in some place.
    Right now, it looks like you’re the only person with that cabability.
    3) NTSC video looks worse on a computer than it will on a TV.
    Especially text. Most especially any text that moves right to left
    (i.e., the opposite direction that the upper/lower interlace scan will
    read it)
    4) Even at its best, SD will look worse than HD.
    My suggestion is to send the DVCPro-NTSC file, and let me tell you if
    it’s going to be acceptable on air. If it isn’t we’ll proceed from
    there.”
    Thoughts?
  • Michael Brodner
    April 27, 2009 at 6:48 pm
    Ill give this a shot. Thanks a bunch.
  • Devin Crane
    April 28, 2009 at 8:40 pm
    How are you playing back the DVCPro Footage FCP or Quicktime? QT defaults to playback DV footage at low quality. If you go into preferences an check Playback at HQ then this might fix your problem.
