Activity › Forums › Apple Final Cut Pro › Final Cut to Compressor 4 – problems?
  • Final Cut to Compressor 4 – problems?
    Posted by Lawrence Eaton on September 26, 2011 at 4:15 pm
    Has anyone experienced the ‘issue’ when you choose SELECT>SEND TO COMPRESSOR option, that it just seems to sit there and mull over the option and eventually Compressor reports an error? Typical one for me is Quicktime error 50.
    Using the tried and trusted CMD+E to export seems to work, but then you have to manually open Compressor after the fact.
    Any help? Any ideas? Any life? 😉
    Lawrence
    Lawrence Eaton replied 15 years ago 1 Member · 0 Replies
  • 0 Replies
