Activity Forums Avid Media Composer Final Cut to AVID?
  • Final Cut to AVID?
    Posted by Ross Spears on August 3, 2011 at 8:54 pm
    I am working on a long-form documentary project and a talented young editor wants to work with me. Trouble is that she lives 200 miles away and uses Final Cut, whereas I use AVID exclusively. I am wondering if she might be able to digitize from my HDV tapes, edit scenes on Final Cut, then send me the lists of shots and time codes, which I could then plug into my AVID Media Compose, which would then — voila — create the identical scene in AVID. Is this just a piple dream? Or is there any way to make the two editing systems compatible?
    Ross
    Never Give Up
    Shane Ross replied 15 years, 1 month ago 3 Members · 3 Replies
  • Shane Ross
    August 3, 2011 at 10:02 pm
    This is a pipe dream. There might be ways to get this to work, if you REALLY work at it, and buy a couple Automatic Duck products, and FCP Reconnect. And really work hard to get things right.
    Sorry, they need to get Avid MC. Keep things simple.
    Shane
  • Michael Hancock
    August 4, 2011 at 2:10 am
    What Shane said. You can try to make this work and buy a bunch of 3rd party stuff to do it, or they can spend $1,000 on the Media Composer crossgrade offer, you can send them a drive with your media and original project, then you email bins back and forth and everything automatically relinks. Fast, easy, pretty much bulletproof (just don’t edit via AMA – it’s not bulletproof yet).
    Why should you waste your time rebuilding their edit because they want to use different software? Make it easy on yourself – require they use Avid.
    Michael Hancock
    Editor
  • Shane Ross
    August 4, 2011 at 5:55 am
    True. By the time you buy both versions of Automatic Duck needed to do this…and that would be problematic…you could buy Avid MC 5.5 for $1000.
    Shane
