Activity Forums Apple Final Cut Pro Legacy Final Cut Timeline into Premiere
  • Final Cut Timeline into Premiere
    Posted by Ross Gerbasi on January 24, 2008 at 11:42 pm
    Not sure if anyone is interested, i am more of a final cut guy then premiere, but i ran into a problem where i needed to move my project into premiere… sooo this is what i did
    We put together ascript for AE a while back, to import final cut projects.
    you can download it here
    https://www.popcornisland.com/downloads
    Follow the normal FC to AE instructions,
    exporting your FC to XML
    and importing the XML into AE
    The next step is easy. Just save your AE project as a Premiere Pro Project. Thats about it to move a project from Final Cut to Premiere using AE as a middle man. I have gotten it to work for me, the AE to premiere part can be a bit messy. Folders and everything are odd when you move them, but everything seems to come over ok.
    hope this helps!
    Oh and by the way if you have any troubles with the FC2AE script please let us know, we are trying to get that nailed down!
    -ross
    Ross Gerbasi replied 18 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
