Activity Forums Apple Final Cut Pro Legacy Final Cut System Set-Up for MOTU V4-HD
  • Final Cut System Set-Up for MOTU V4-HD
    Posted by Ramon Blandino on March 10, 2011 at 7:23 pm
    Jerry
    I bought your excellent and instructional DVD. However, you presented 3 interface device -Motu V4-HD it is not one of them.
    I will like some asitance from anyone
    I just bought a MOTU V4-HD and tried to set a system that included:
    Mac Pro Quad 2.5 Mz
    Final Cut Studio 5.1 HS retail version
    G Drive External 2 TB Hard Drive
    I can not capture or get video in the Final Cut
    I conected the Motu via Fire Wire to the Firewire 400 port
    the G Drive in the Mac firewire 800 port
    the Sony DSR- 1800 to the SDI input of the MOTU and the 9 pin
    controler in the conectors in both unites (MOTU and DSR-1800)
    Paul Jay replied 15 years, 5 months ago 3 Members · 3 Replies
  • Michael Gissing
    March 10, 2011 at 9:26 pm
    Firstly I would upgrade the FCP software. 5.1 is old and the drivers for the MOTU may not work with that version. I suggest you contact MOTU as the most likely scenario is your OS, system and version may not work with their interface and they should be able to advise you of minimum system requirements or point you to legacy drivers.
    I have been interested in the MOTU interfaces but have never heard from anyone who uses one so I am interested in hearing what transpires.
  • Ramon Blandino
    March 10, 2011 at 10:40 pm
    Thank you for your suggestion, I found a Motu forum here and opened a tread with the same question, hopefully the Motu people can share som light on this
  • Paul Jay
    March 10, 2011 at 11:02 pm
    MOTU is great with audio interfaces, but the video interfaces i’ve tested can’t be compared to Matrox, AJA or Decklink solutions.
    Great specs doesn’t mean the drivers are good.
    The first MOTU video interface i’ve tested with FCP had PAL/NTSC signals messed up.
    You should upgrade to FCP7 at least to get it to work.
    Then you should choose the proper EASY SETUP.
