Activity › Forums › Apple Final Cut Pro Legacy › Final Cut Studio Program Integration
  • Final Cut Studio Program Integration
    Posted by David Cooke on February 20, 2007 at 9:02 pm
    Does Final Cut Studio operate “between the individual programs” like Adobe Creative Suite? in other words,
    in Adobe, the Adobe bridge product lets you “fix” a photoshop file that is inside of After Effects. then it automatically updates the fix inside
    of After Effects and or Premier without you having to go in and re-export/re-import the file. I would call this
    ‘seemless integration’. Myself and some collegues have just started using “Motion”, but don’t see a way to do
    that same thing easily. So if I have a Motion clip on the FCP timeline, can I double click it to open up Motion, fix the file and it
    then automatically updates ON the FCP line?
    If not, this is one case where Apple Needs to play catch up quick!
    Arnie Schlissel replied 19 years, 7 months ago 3 Members · 2 Replies
  • John Pale
    February 20, 2007 at 9:12 pm
    [1Videomilkman] “So if I have a Motion clip on the FCP timeline, can I double click it to open up Motion, fix the file and it
    then automatically updates ON the FCP line?”
    Yes. Control (or right) click on the clip in the timeline and select ‘open in editor’.
    This only works if you are using the Motion project file as your video clip and you have Motion set as the external editor for video clips in your preferences.
  • Arnie Schlissel
    February 22, 2007 at 1:58 am
    [1Videomilkman] “Adobe bridge product lets you “fix” a photoshop file that is inside of After Effects. then it automatically updates the fix inside”
    I do this with FCP all the time. Right click on any still image file & it will open up in whatever photo editor you’ve designated in your system preferences. When you save the file it will be automatically updated in FCP. Same with audio sent to Soundtrack or mograph files sent to Motion.
    Arnie
    Now in post: Peristroika, a film by Slava Tsukerman
    https://www.arniepix.com/blog
