Activity › Forums › Apple Final Cut Pro Legacy › Final Cut Studio 6.0.5
Posted by Peter Fuhrman on March 15, 2009 at 11:03 pmI cannot export any video files from my Final Cut Pro. I am using version 6.0.5 with FCP Studio 2.
Every time I try to export video I get the Mac OS spinning pinwheel. I have to force quit. I have shut down and rebooted the system twice. Same issue.
I have tried exporting from different sequences and FCP projects and still cannot export. Any thoughts or suggestions? Thank you.
Michael Copeland replied 15 years, 6 months ago 7 Members · 9 Replies -
David Roth weiss
March 15, 2009 at 11:06 pm1. Trash Prefs.
2. Run Disk Warrior on all drives
3. Delete all render files using Render Manager and then re-render.David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
Don Greening
March 15, 2009 at 11:22 pmOr FCP is looking for a scratch disc/external hard drive for exporting that is no longer connected to your system.
– Don
David Roth weiss
March 16, 2009 at 1:17 amThere is no native Flash component in FCS — you would have install Adobe Flash or some other app. Do you have something? If so what?
David Roth Weiss
Director/Editor
Don Greening
March 16, 2009 at 1:57 am[Peter Fuhrman] “I cannot export to Flash, but I can any other format. “
I ran across this great tidbit of information the other day: if you create a QT H.264 .mov file and change the .mov suffix to .f4v your movie will play in a flash player without any other changes. Here’s the article:
https://provideocoalition.com/index.php/aadams/story/the_quicktime_conundrum_solved_by_our_readers/
Good luck.
– Don
Rafael Amador
March 16, 2009 at 1:13 pm[Don Greening] “I ran across this great tidbit of information the other day: if you create a QT H.264 .mov file and change the .mov suffix to .f4v your movie will play in a flash player without any other changes. Here’s the article: “
Right. But stop being played in QT (unless you have Perian installed).
The thing is to make that both players can open it.
I have to try with .mv4. It works with QT player but I have to try with Flash Player. In theory should work.
rafael(and here some clips for the friends: https://www.vimeo.com/2694745 )
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Mark Maness
March 16, 2009 at 3:53 pm[Rafael Amador] “I have to try with .mv4. It works with QT player but I have to try with Flash Player. In theory should work. “
Good theory…. But no go.
_______________________________
Wayne Carey
Schazam Productions
https://web.mac.com/schazamproductions
schazamproductions@mac.com -
Dave Jenkins
March 16, 2009 at 10:30 pmIt works in Flash CS4 as a f4v
Dajen Productions, Santa Barbara, CA
MacPro Two 2.8GHz Quad Core – AJA Kona LHe
FCP 6.0.4 OS X 10.5.5 QT 7.5.5 -
Michael Copeland
March 1, 2011 at 6:03 amThe interactive media company I work for requires all f4vs for the online flash player. I am trying to move into a final cut workflow
Are you saying that if I have Flash CS4 or CS5 on the mac with Final Cut, I will be able to export f4vs through Compressor?
Thanks for your help.
