Activity › Forums › AJA Video Systems › Final Cut Studio 5.1 Upgrade
  • Final Cut Studio 5.1 Upgrade
    Posted by Ben Cheng on June 13, 2006 at 9:21 am
    Hi guys,
    I’m running FCP 5.0.4 & like to upgrade to 5.1.1.
    Should I do the following?
    (1) un-install 5.0.4
    (2) install 5.1
    (3) upgrade to 5.1.1
    or install 5.1 to over-write 5.0.4?
    Anyone running FCP 5.1.1 with QuickTime 7.1.1 & AJA Kona 2.0 driver?
    Any advice is much appreciated =)
    Cheers,
    Ben Cheng
    The Media Village
    Singapore
    Jared Picune replied 20 years, 3 months ago 2 Members · 1 Reply
  • Jared Picune
    June 13, 2006 at 4:05 pm
    If you have the time I would suggest a clean install of your os and FCS, however, I just installed it over 5.0.4 and have not had any issues. I am also running the latest version of QT7.1.1 and the new Kona Drivers. I am on a Kona 2 by the way. Everything seams to be working wonderfully (knock on wood) and I have jun the gambit so far doing HD and SD capture and well as general editing and layback.
    Jared
    Idea Spring Editing, Inc.
    Denver Final Cut Pro UG
