Activity Forums Apple Final Cut Pro Legacy Final Cut Studio
  • Final Cut Studio
    Posted by Rick Helderman on October 26, 2013 at 7:32 pm
    Hey, I can’t seem to get past square one. My hard disk went bad so I had it replaced now I can’t log and transfer my video to final cut. I can see it and drag it to the queue and it says clips are queued but when I click on them in the status area it shows a stop sign with a exclamation point in it and it says there is no data. I had this same problem when I originally loaded final cut and it’s driving me crazy. Oh yea and it also says that the queued clips are idle.
    John Street replied 12 years, 11 months ago 3 Members · 2 Replies
  • Shane Ross
    October 27, 2013 at 2:52 am
    Did you install FCP from scratch?
    Shane
    Little Frog Post
  • John Street
    October 27, 2013 at 5:25 pm
    I have run into this problem when the hard drive containing the raw footage is connected by USB … the problem clears up as soon as I connect via Firewire … not sure this will help, but that’s one of the weird workarounds that has helped me …
    John Street
    http://www.inpoint.tv
    Mac OS 10.7.5, FCS 7.0.3, QT 7.6.6, Mac Pro 2x3GHz Quad-Core, 16GB Ram
