Activity › Forums › Apple Final Cut Pro Legacy › Final Cut Studio 2 Install
Posted by Rogelio Cordovez on May 23, 2007 at 3:02 pmWe are getting our Final Cut Studio 2 tomorrow.
Rogelio Cordovez replied 19 years, 3 months ago 5 Members · 9 Replies -
Steve Eisen
May 23, 2007 at 4:59 pmWhen you install FCS 2, it will overwrite version FCS 1. Apple does not recommend having more than 1 version of FCP on the same boot system. That is why it is recommended to clone your system HD before you install.
Up until Final Cut Studio, it was possible to have multiple versions of FCP on the same system and work without conflicts. Before upgrading, you would rename your Final Cut Pro Application. I still have version 1, 2, and 3 on my G4 400 and my G4 Dual Gig I have 3.04, 4.5 and 5.04. Both those systems are retired.
Steve Eisen
Eisen Video Productions
Director-At-Large
Chicago Final Cut Pro Users Group -
David Roth weiss
May 23, 2007 at 5:05 pmThe answer is simple:
1. clone your existing system drive to an inexpensive firewire drive using Carbon Copy Cloner (free software).
2. test the clone to make certain it boots
3. put the clone away for safe keeping
4. install FCS2 to your system drive over your existing version and take a test drive.
a) if everything works as you like it and as its supposed to, you’re all good.
b) if its not perfect, erase your system drive and rebuild from scratch i.e. OS, then FCS2 and other apps.Meanwhile, your clone allows you to go back to 5.x.x if your want and to know that you have not lost a single file.
David Roth Weiss
Director/Editor/Post-production Supervisor
David Weiss Productions, Inc.
Los Angeles -
Drazen Stader
May 25, 2007 at 4:41 pmHi guys,
I am in the same situation will be installing FCS 2 in a couple of days, and I have final cut studio 5.1.4. installed in hd system. I just want to make sure I understood coorectly your info so I will revise a couple of stuff:
1. When you install FCS 2, it will overwrite version FCS 1.1Does this mean that I don
David Roth weiss
May 25, 2007 at 5:07 pmI’m installing this very minute, doing so right over FCS1 without uninstalling, but with my clone tucked away for safe keeping.
In theory, you can install right over the top — its certainly worthy of a try if you have other apps installed on your computer.
If its not up to snuff and you want to start over from scratch, just boot from your clone, use Disk Utility to erase your system drive, and install the OS from scratch. Then install FCS2.
David Roth Weiss
Los Angeles -
Andrew Kemler
May 27, 2007 at 3:00 amsome questions from a nervous amateur:
regarding the clone, what if I have software on my computer that I no longer have the disks or serials for? If I have to erase the HD and rebuild, will I be able to just copy the applications from the clone?
how do you test to see if the clone will boot up?
If I have to reinsall OSX, it will be an older version (obviously); will I be able to go to software updates to get it updated.
For the clone, is it ok to use a large firewire HD that will have other media on it?thanks
andy -
Andrew Kemler
May 30, 2007 at 8:17 pmc’mon it wasnt that stupid a question..someone? anyone?
thanks
andy -
Rogelio Cordovez
June 2, 2007 at 3:56 pmI did a Carbon Copy of my HD and then proceed to install FCP Studio 2, everything went well, I installed on top of FCP Studio 1, and it just erased previous versions and installed only what it needed to.
So far is Good (knock on wood).
