Activity Forums Apple Final Cut Pro Legacy Final Cut Speeded up my video.
  • Final Cut Speeded up my video.
    Posted by Dave Miller on June 7, 2011 at 10:01 pm
    This is my first post here. My problem is that I have a video that plays normal in QuickTime pro and soundtrack pro. When I bring it into the timeline the Audio stays normal but the video speeds up. When the video reaches the end it fills the rest with a black screen. When I export the video becomes normal when played in QuickTime.
    I looked the problem up but can’t get any of the solutions to work. I tried restarting the computer, I tried deleting the preference list, I checked to see the ripple sequence was checked (it was.), and I checked the playback options in the settings panel for if playback was set to 100% (it was.).
    So to recap Going into Final cut the video is normal. In final Cut, video is speed up. Exported out video is normal.
    I am using a Mac Pro from early 2008, Final Cut Pro 7.0.3, QuickTime Player Version 10.0 (118), And Mac OS x Version 10.6.7, Processor 2×3 ghz ruad-core Intel Xeon, 4gb 800 mhz DDr2 fb-dimm
    Chris Swere replied 14 years, 4 months ago 3 Members · 4 Replies
  • Sunny Jhooty
    June 8, 2011 at 1:26 am
    i would start off by making sure your footage codec and your timeline codec are the same.
  • Dave Miller
    June 9, 2011 at 5:32 pm
    the codec of video is pro res 422 and the timeline pro res 422 (hq)
  • Dave Miller
    November 3, 2011 at 6:59 pm
    Sorry for a such a long reply but That worked thank you.
  • Chris Swere
    April 13, 2012 at 3:51 pm
    I am running into the same issue and I tried what you suggested but it did not work.
    The codecs for my footage and timeline are the same (DV/DVCPRO – NTSC); I created a new sequence, and when asked if I wanted to change the sequence settings to match the clip, I said yes.
    The video is still speeding up. Any other suggestions?
    Chris
