Activity Forums Apple Final Cut Pro Legacy Final Cut Setup with Kona 3x
  • Final Cut Setup with Kona 3x
    Posted by Gerry Condez on August 5, 2009 at 4:06 am
    Hi, After years of slowly building a Final Cut 6 system, I would like to know if someone here can help me what is the proper way to connect and select options for setting it up. My system is an Apple G5 dual 2.7, OS 10.4.11, 8GB of RAM, Kona 3x Version 6.0.3 with junction box, Atto UL4D pciX, dual channel RAID 0, 5 Seagate ST3300007LW per burly.
    I have a Canon HV30 and tried capturing 1080i, connected to the firewire in front of the G5. A question that I have is how does the Kona and FCP work together. Seems that nothing is real time at this point. Rendering is very long for a 20 sec. clip with effects. Is that normal? Anyone still uses a Kona 3x?
    Thank You.
    Shane Ross replied 17 years ago 2 Members · 3 Replies
  • Shane Ross
    August 5, 2009 at 6:45 am
    [Gerry Condez] “I have a Canon HV30 and tried capturing 1080i, connected to the firewire in front of the G5.”
    OK…when you do that you are capturing via firewire, and not using the Kona card at all. The Kona card is a capture card. You attach decks to it, and then capture video using it. But the Kona 3x only captures via SDI, and that camera doesn’t have SDI output, so that card cannot capture from that camera.
    [Gerry Condez] “A question that I have is how does the Kona and FCP work together.”
    As stated, the Kona is a CAPTURE CARD. It isn’t a hardware accelerator. It doesn’t make the system run faster, it doesn’t eliminate nor speed up rendering. It allows you to connect a deck (DVCPRO HD, Digibeta, HDCAM for example) and capture video, either as ProRes or Uncompressed, or DVCPRO HD…whatever the card and FCP support.
    [Gerry Condez] “Rendering is very long for a 20 sec. clip with effects. Is that normal?”
    Well, HOW long? With HDV native, yes, it is very normal to have long render times. That is a processor intensive format, HDV. The long GOP structure is the reason. Many people, myself included, capture HDV as ProRes. And this is possible via firewire, but you don’t need the Kona to do it:
    https://library.creativecow.net/articles/poisson_chris/hdv-prores.php
    And the only way to capture to ProRes from that camera is to get the Convergent Design HD Connect SI device…converts Firewire to SDI and deck control…VERY sweet box. We use it for all the work we do with HDV. THEN the Kona card comes into play.
    [Gerry Condez] “Anyone still uses a Kona 3x?”
    Kona 3…the regular one, on a MacPro…not the 3x for PCIx machines…yes, I do.
    Shane
  • Gerry Condez
    August 5, 2009 at 6:54 pm
    Hi Shane,
    Thank you very much for the information and your time. I’m very glad to get help from here. I saw the Convergent Design HD Connect SI you mentioned, I’ll go B&H tomorrow.
    I saw tons of bnc connection on the Kona junction box, I think I only need one for the Convergent Design. Can I connect it to any of those 2 SDI ins? Do I need an SDI monitor to view the out going video? Can I use a regular LCD with HDMI? I saw a Mini Converter from AJA (Hi5) will that work? Any recommendations? Thank you again.
    Gerry
  • Shane Ross
    August 6, 2009 at 4:35 am
    [Gerry Condez] “Can I connect it to any of those 2 SDI ins?”
    Yup. We have two of those boxes here on our HDV decks. We connect them to our Kona LHe and Kona 3 systems.
    [Gerry Condez] ” Can I use a regular LCD with HDMI?”
    For….? The Kona 3x doesn’t have HDMI out.
    [Gerry Condez] “I saw a Mini Converter from AJA (Hi5) will that work? “
    Ahh…to go SDI to an HDMI monitor. Sorry, I don’t have any experience with that box.
    Shane
