Activity Forums Apple Final Cut Pro Legacy Final Cut Sequence Settings for Blu Ray Slide Show
  • Final Cut Sequence Settings for Blu Ray Slide Show
    Posted by David Mayer on September 2, 2011 at 5:06 pm
    I will be making a Blu Ray slide show with high resolution TIFF files and music. I have found a lot of info on the best Compressor settings for creating the Blu Ray file, but less on the Final Cut settings. What is my best bet for the sequence settings in the Final Cut timeline?
    Dave
    iMac 2.8 GHz Intel Core i7, 8 GB
    OS 10.6.2
    Final Cut Pro 7.0
    David Mayer replied 15 years ago 4 Members · 19 Replies
  • 19 Replies
  • Jerry Hofmann
    September 2, 2011 at 9:33 pm
    1080 ProRes 422 or LT most likely… 29.97 if in the US… 25fps if in PAL land…
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Steve Eisen
    September 3, 2011 at 5:20 am
    Check out Gee Three’s PhotoMotion. It saves a lot of time when creating slide shows.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • David Mayer
    September 3, 2011 at 1:05 pm
    Thanks much, Jerry and Steve.
    Dave
    OS 10.6.2
    Final Cut Pro 7.0
  • David Mayer
    September 3, 2011 at 1:40 pm
    Jerry,
    How does this look for the Sequence Settings?
    Frame Size 1920 x 1080
    Aspect Ratio HDTV 1080i (16:9)
    Pixel Aspect Ratio HD (1280 x 1080)
    Compressor Apple ProRes 422 (HQ)
    OS 10.6.2
    Final Cut Pro 7.0
  • Jerry Hofmann
    September 3, 2011 at 2:43 pm
    The pixel aspect ratio isn’t right… should be square…
    Just load the “sequence preset for ProRes HQ 1080… 30p might be just the ticket for a slide show too.
    Current DVD:
  • Steve Eisen
    September 3, 2011 at 5:55 pm
    Keep in mind using ProRes HQ will yield very large render files.
    Steve Eisen
    Vice President
  • David Mayer
    September 3, 2011 at 9:55 pm
    will do
    OS 10.6.2
    Final Cut Pro 7.0
  • David Mayer
    September 3, 2011 at 10:08 pm
    Jerry,
    There is no preset with that exact name.
    Would it be this one?
    Preset is called: ProRes 422 (HQ) 1920×1080 30p 48 kHz
    and results in the sequence menu showing an aspect ratio of: HDTV 1080i (16:9)
    Thanks again,
    Dave
    OS 10.6.2
    Final Cut Pro 7.0
  • Jerry Hofmann
    September 3, 2011 at 11:01 pm
    That will work…
    Jerry
    Current DVD:
  • Rafael Amador
    September 4, 2011 at 12:20 am
    [david mayer]
    and results in the sequence menu showing an aspect ratio of: HDTV 1080i (16:9)”
    I would change the sequence to Progressive (NONE).
    You are working with stills. No interlacing involved.
    rafael
    http://www.nagavideo.com
