Activity Forums Apple Final Cut Pro Legacy Final Cut Rro 5-HDCAM
  • Final Cut Rro 5-HDCAM
    Posted by Lawrence Gough on September 3, 2006 at 1:25 pm
    Hi All
    I am about to purchase a new G5 quad and I am shooting my next short film on the SONY HDW750P HDCam. my question is this:-
    Can I perform a suitable offline edit by hiring a HDcam deck and capture directly into final cut pro 5/G5?
    I would appreciate anyones thoughts on my workflow solution. I only need to do an offline edit
    many thanks
    Lawrence Gough
    Lawrence Gough
    Hoax-films.com
    Tony replied 19 years, 12 months ago 3 Members · 2 Replies
  • Walter Biscardi
    September 3, 2006 at 2:57 pm
    Sure, just purchase a Kona 3 system and you can capture to any resolution you want for the offline. I would suggest DVCPro HD as you get the small data rates, but you maintain a very high quality HD so you can better see what your footage really looks like.
    You simply set up the Kona for a DVCPro HD Easy Setup (or whatever format you want to capture to) and start digitizing. The Kona will convert your HD-SDI signal to whatever you have chosen.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Tony
    September 3, 2006 at 6:08 pm
    Are you shooting 1080 50i by chance?
    If so I recommend you shoot in progressive at 24P or 25P depending on where you are located in the world.
    Tony Salgado
