Activity Forums Adobe Premiere Pro Final Cut rewrapped DVCPROHD MOV won’t import into CS3
  • Final Cut rewrapped DVCPROHD MOV won’t import into CS3
    Posted by Nathan Quattrini on June 16, 2009 at 4:08 am
    My friend color corrected footage that I exported as P2 (it was P2 from the beginning) from CS3. He worked on it in Final Cut and gave me back an Mov file which is rewrapped as DVCPRO HD. I tried everything, including making a DVCPRO HD projct in Premiere and importing, and it still says ‘Codec is missing or unsupported’. How can I open this file? I’m going nuts trying to figure it out.
    Larry Applegate replied 17 years, 1 month ago 5 Members · 5 Replies
  • Jon Barrie
    June 16, 2009 at 5:12 am
    Sorry to be the bearer of bad news, but unless you have an Apple system with FCP or FCS on it you can’t read the file format. The codecs are proprietary for FCP environments and that means no PC support either.
    You need the file converted or re exported to a non-FCP environment, namely ProRes (can get downloads for the playback of it, PC too, you will get a gamma shift in the export) or Animation. File sizes will be much larger in Animation, but you won’t lose any quality and you can use it on any system.
    – JB
    Jon Barrie
    aJBprods
    http://www.jonbarrie.net
  • Eric Jurgenson
    June 16, 2009 at 1:26 pm
    Check out the raylight decoder:
    https://www.dvfilm.com/raylight/decoder/index.htm
  • Nathan Quattrini
    June 16, 2009 at 9:47 pm
    forgot to mention I`m on a Mac 🙁
  • Greg Booth
    June 17, 2009 at 1:30 am
    You can try out a demo of our Calibrated{Q} DVCProHD Decode for OSX here:
    https://www.calibratedsoftware.com/QDVCProHD.asp
    Cheers,
    Greg
    Calibrated Software
  • Larry Applegate
    July 11, 2009 at 11:11 pm
    I have Final Cut Sudio 2.0 on the same machine as Adobe Production Bundle CS4. But in Premiere I still can’t find the right codec. How can I install it into Premiere?
    Regards,
    Larry
