Activity Forums Apple Final Cut Pro Legacy Final Cut Rendering problem
  • Final Cut Rendering problem
    Posted by Jefferson Andres on October 10, 2013 at 4:30 pm
    Hi again guys ^_^
    I am making a 30 sec video in FCP, and my problem is I put an image which is in PSD file type and it only has 4 images inside the PSD, so why my rendering time takes 1-2 hours with just 3 text and 1 backround on it?
    Alexander Kallas replied 12 years, 10 months ago 2 Members · 5 Replies
  • Jefferson Andres
    October 10, 2013 at 9:43 pm
    I’m referring for rendering time and here’s my settings
    Apple/ ProRes 422 (HQ) NTSC 48kHz
    NTSC CIR 601 DV (720×480)
    what happen is I put PSD file with 4 images inside, resize it, then its moving slowly from right to left for 30 sec. then it takes too long to render each PSDs
  • Alexander Kallas
    October 10, 2013 at 10:27 pm
    What res are those PS images? that’s where the rendering time goes.
    Cheers
    Alexander
  • Jefferson Andres
    October 10, 2013 at 10:29 pm
    dimension is 1500 x 1080
  • Jefferson Andres
    October 11, 2013 at 2:09 am
    what do you mean by flattened the PSD file? I don’t want to do that because I’m going to animate those images inside the PSD
  • Alexander Kallas
    October 11, 2013 at 5:55 am
    [Jefferson Andres] “dimension is 1500 x 1080”
    If your time-line is NTSC CIR 601 DV (720×480), the dimensions of you PS files should be
    DV NTSC 4:3 720×540.That’s where your rendering problem is.
    Cheers
    Alexander
