Activity Forums Apple Final Cut Pro Legacy Final Cut Pro7 Menus slow to appear.
  • Final Cut Pro7 Menus slow to appear.
    Posted by Kirk Pitts on May 18, 2013 at 7:12 pm
    Has anyone seen a problem with FCP7 where if you select a menu item you get the spinning cursor and the menus take 5 seconds or more to appear?
    10.8.3 2012 2.3 i7 with 16 gigs ram. stock 5400 rpm 1 tb drive.
    Installed FCP X and started motion 4 and FCP 7 before I ran FCPX and followed all other steps to run both on the same partition.
    I’ve use FCP remover and completely reinstalled but it makes no difference.
    Kirk Pitts replied 13 years, 3 months ago 1 Member · 1 Reply
  • Kirk Pitts
    May 19, 2013 at 11:03 pm
    Could never find a reason for the problem. As I looked through the console logs there were errors as FCP looked for resources. Reinstall of OSX seems to have cleaned up the issue.
