Activity Forums Apple Final Cut Pro Final Cut Pro X Re-Render issue
  • Final Cut Pro X Re-Render issue
    Posted by Damian Bartolacci on May 21, 2014 at 8:01 pm
    Hello!
    I’ve since deleted my original post but decided to re-enstate my previous inquiry on this subject. Again, any information at all about this situation would be greatly appreciated!
    I’ve been working on a couple projects in FCPX. After all my effects, clips, and texts render, I quit the project. When I re open it, FCPX always re-renders a large chunk of the project timeline. I’m wondering why this happens or if there is a way to prevent this from happening?
    I can turn off Background Render but that wouldn’t prevent FCPX from opening up with Un-rendered files that were previously rendered.
    I hope this post makes sense. Thank you so much for any help!
    Damian Bartolacci
    Damian Bartolacci replied 12 years, 4 months ago 2 Members · 2 Replies
  • Nikolas Bäurle
    May 21, 2014 at 9:29 pm
    Its a bug. I’ve had that problem with older versions and with the current one as well. Sometimes when I render manually (ctrl+R) it doesn’t render everything, even when its done rendering, then I turn on background rendering to force render the remaining bits and pieces.
    “Always look on the bright side of life” – Monty Python
  • Damian Bartolacci
    May 21, 2014 at 9:45 pm
    Thanks for the info Nikolas! Hopefully it gets sorted out in the next update!
    Damian
