Activity › Forums › Apple Final Cut Pro › FInal Cut Pro X Multicam angle is black
  • FInal Cut Pro X Multicam angle is black
    Posted by Bill Moede on March 4, 2015 at 4:48 pm
    I have an odd problem with Final Cut Pro X Multicam.
    When I create a new Multicam Clip; CAM A, CAM B CAM C.
    Cam A is black, I can cut to CAM A but it’s black when I do that.
    And in this project, it’s only the CAM A footage that’s the problem.
    I can work with the CAM A footage alone and it’s fine.
    CAM A and CAM B are SD DV tape captures CAM C is a SD Quicktime file from a JVC camera.
    I’m running FCP X Version 10.1 on a Macbook Pro, OSX 10.9.4 2.3 GHz. 12Gb memory.
    Bill Moede replied 11 years, 6 months ago 3 Members · 3 Replies
  • Noah Kadner
    March 4, 2015 at 5:58 pm
    Have you optimized the footage? Could be a codec issue. Also are you sure it’s active in the angle editor? It’s the little TV icon on the top left of the track.
    Noah
    FCPWORKS – FCPX Workflow
    Call Box Training
  • Robin S. kurz
    March 5, 2015 at 2:13 pm
    Could it be that you’re simply switching to a section of the angle that has no video at that time??
    – RK
    ____________________________________________________
    Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
  • Bill Moede
    March 5, 2015 at 2:24 pm
    Nope, the entire 40 minutes is black. If I put that clip into a multicam clip by itself then it’s fine. And it’s only that clip. I did a recapture of that tape and get the same symptom. My best guess is that there is some garbled time code data on that tape. Today I’m going try a pass through Compressor to generate new a file with new and intact time code.
