Activity Forums Apple Final Cut Pro Final Cut Pro X – Move Rotation Anchor Point
  • Final Cut Pro X – Move Rotation Anchor Point
    Posted by Thomas Hermon on September 13, 2012 at 3:39 pm
    I’m really struggling to figure out how to move the centre anchor point on an image in final cut pro X. I’m trying to animate a car tachometer so need to center point to be exactly in the centre of the needle or it rotates on the wrong axis.
    I’ve spent the last hour looking for a tutorial and can’t find a decent one anywhere!
    Many Thanks
    Tom
    David Morris replied 11 years, 4 months ago 3 Members · 7 Replies
  • 7 Replies
  • Jeremy Garchow
    September 13, 2012 at 5:34 pm
    There’s an “anchor” parameter in the “transform” section of the inspector.
  • Thomas Hermon
    September 14, 2012 at 7:05 am
    Hi Jeremy,
    Thanks for that, I’ve found the anchor parameter but I still haven’t found out how to move the anchor points?
    Many Thanks
    Tom
  • Thomas Hermon
    September 14, 2012 at 7:19 am
    Ignore the above! Found it!
  • David Morris
    May 1, 2015 at 2:59 am
    How do you move the center point of an image in fcpx?
  • David Morris
    May 1, 2015 at 3:25 am
  • Jeremy Garchow
    May 1, 2015 at 3:30 am
    Open the Transform controls in the inspector and move the anchor point x,y controls.
  • David Morris
    May 1, 2015 at 3:43 am
    Is there a way to move it with the mouse? Seems a bit cumbersome using the xy controls.
