Activity › Forums › Apple Final Cut Pro Legacy › Final Cut Pro X Lag during transitions.
  • Final Cut Pro X Lag during transitions.
    Posted by John Mark on November 13, 2012 at 2:37 am
    I am having an issue with FCP when it comes to adding transition, example the cross dissolve transition. I am using a Imac with spec, Intel core I3 and 4GB on ram and 132GB of available free space. The original files were converted from AVCHD to MP4 from using Clip Wrap 2 (Trial) which works great, and the file codec is H.264. Any reason why this might be happening.
    Thank you.
    A News Graphic Lover
    Rafael Amador replied 13 years, 10 months ago 2 Members · 1 Reply
  • Rafael Amador
    November 13, 2012 at 5:28 am
    [John Mark] “The original files were converted from AVCHD to MP4 from using Clip Wrap 2 “
    Wrong workflow.
    Just must convert the files to Prores.
    Any flavor of h264 & Mp4 are not supported by FC.
    Anyway, your psot is confusing. The title mention FCPX, the you talc about FCP. The “legacy”?
    FCPX should manage H264 native.
    rafael
    http://www.nagavideo.com
