Activity › Forums › Creative Community Conversations › Final Cut Pro X does not have Log and Capture (or transfer) feature
Posted by Randy Ohara on June 21, 2011 at 2:36 pmJust purchased FCP X, it doesn’t have a log and capture command. The reason I purchased was to use the Canon MXF plug in to import my files from my Canon XF100. All the Apple site says is that Canon XF files are supported with 3rd party software – anyone know how/where I can make this work?
Travis Lee moser replied 13 years, 11 months ago 9 Members · 14 Replies -
Bret Williams
June 21, 2011 at 2:41 pmI have not been able to find a page for Final Cut Pro X on the apple site. Do you have a link? The only data is in the app store. I think you’re referring to FCP 7,
I would assume though, that FCP X can natively use your footage. I haven’t downloaded yet. Is it just import?
Hector Berrebi
June 21, 2011 at 2:46 pm[Bret Williams] “I would assume though, that FCP X can natively use your footage. I haven’t downloaded yet. Is it just import?”
i opened a card i shot on the AGAF100, FCPX refers to it as a camera archive.
i clicked import all and in a few seconds was able to work with all my shots, apply effects and color correction to the all quite smoothly.
i didn’t select the create proxies or prores option so these were native AVCHD files
Hector Berrebi
prePost Consulting -
Tim Wilson
June 21, 2011 at 2:50 pmGary Adcock’s article is coming any minute, I promise. 🙂
Here’s what it says about this:
INGEST OR IMPORT?
Since there is not a way to open previous projects, your best practice here is to start from scratch with the newest tapeless camera you have access to.However, while Apple’s approach with FCPX defaults to ingesting the media directly from the camera, a reality is that we no longer shoot our projects on a single camera or a single form of media.That concept precludes using the camera as a media ingest device, especially when you consider that many cameras use USB as the only connection, yet I can transfer from SxS, SDHC or CF cards over SATA at 10x the speed of USB.
My main reasoning for this is simple- why bother hanging a camera when you can edit with the content directly from the cards while the transfer of media is going on in the back-ground? The only difference is when the media copy is complete your timeline playback be-comes noticeably faster.
Currently FCP X easily supports the DSLR cameras, Panasonic’s P2 and AVC-I format cameras along with any Apple Devices. My pre-release version of the software had some issues with importing of Sony’s EX and XDCAM formats, so I resorted to using the XDCAM Transfer Tool.
There is no support for any of the RAW camera formats or frame based workflows like DPX or Tiff working with this release. Workarounds for higher end cameras include using the QT reference files with R3D media, and just importing ProRes from the ARRI Alexa. However in both of these cases much of the camera metadata is ignored.
Randy Ohara
June 21, 2011 at 2:51 pmThe Canon XF100 uses MXF file format – and the FCP X import feature doesn’t recognize it. In FCP 7 you can use the Canon XF plug in and use the log and capture command (which is missing from X)
John Godwin
June 21, 2011 at 3:57 pmSo, how did you use the XDcam transfer tool, please?
I’ve just installed FCP X on my secondary edit system after making system clones onto a partitioned drive and an external drive. I can still run FCP 7 on my system, so I haven’t lost anything, just gained what I hope is a new editing app that’ll be added to rapidly by Apple.
An import to FCP X from my NEX FS-100 worked fine, but no such simple luck with XDcam EX cards.
Best,
John -
John Godwin
June 21, 2011 at 4:40 pmNever mind, just exported files from the XDcam transfer tool to a folder and then imported that. Clumsy but works.
Best,
John -
Jimmy Strater
June 21, 2011 at 5:41 pmSame problem here. i have a Canon XF100. How do I get my video into Final Cut Pro X?
35 years and never had a real job
David Bishop
June 21, 2011 at 6:00 pmSame here. I downloaded FCPX this morning. I thought it was supposed to support MXF native, but I can’t even find a way to make it work with “extra software”.
David Bishop
June 21, 2011 at 8:08 pmEvidently the Canon XF Cameras aren’t supported: https://help.apple.com/finalcutpro/cameras/en/index.html
