Activity Forums Apple Final Cut Pro Legacy Final Cut Pro X Converting from 7
  • Final Cut Pro X Converting from 7
    Posted by Bryce Douglass on June 28, 2013 at 12:21 am
    Hello
    I have a documentary film that I have been working on for some quite time. It was started in Final Cut 7 and I tried converting the project to Final Cut X and I’m using the 7tox application. I have exported the Final Cut 7 Sequence to an XML file and opened it up using 7tox. What’s very strange is the compressed sequence Final Cut X makes is out of sync in some areas. So out of sync that you can hear audio from 10 minutes ago. I have posted a screen shot so you can see what I’m talking about. The green audio is the out of sync audio and the blue video clip with the correct audio is sometimes muted and no longer there and I can’t even adjust it’s volume no matter where in Final Cut X I try too. I’ve never converted before and not sure if I’m doing something wrong or if this is a bug in Final Cut X or maybe even 7 itself.
    Bryce
    Steve Eisen replied 13 years, 3 months ago 2 Members · 1 Reply
