Activity Forums Creative Community Conversations Final Cut Pro X: Best practices for updating
  • Final Cut Pro X: Best practices for updating
    Posted by Kevin Patrick on October 24, 2012 at 12:40 am
    Perhaps I’m the last one to come across this article, but for anyone who has not seen it, I thought it might be worth while info. Especially given the fact that they just released a new version. Although it appears that this particular article was just published today.
    You’d think this info would some how be available to anyone who is upgrading. Which now only takes one click in the App Store app. I finally stumbled across it reading about the release on FCP.co.
    https://support.apple.com/kb/HT5550?viewlocale=en_US&locale=en_US
    Andre Grove replied 13 years, 10 months ago 3 Members · 4 Replies
  • Andre Grove
    October 24, 2012 at 12:59 pm
    Wish I read this first. The new update is not reading my project files even after I have updated them and the app store keeps updating the fcpx app motion and compressor
  • Kevin Patrick
    October 24, 2012 at 1:08 pm
    [Andre Grove] “Wish I read this first.”
    I’m not sure how you could, since Apple didn’t point it out to you when you upgraded using their App Store app.
    I’ve never seen this suggestion to backup your existing version of the (or any other) app.
    The way I read this, you should backup up your Projects (and Events) and backup the current version of FCPX. I guess because if you have an issue with the new version working with your projects … you’re supposed to re-install the old version?
    Unless I missed something in the article, I’m not sure what to do if you want to actually need to use your older version of FCPX. Drag the new version to the trash and drag the old version to the Applications folder?
  • Dave Gage
    October 24, 2012 at 7:44 pm
    [Kevin Patrick] “Unless I missed something in the article, I’m not sure what to do if you want to actually need to use your older version of FCPX. Drag the new version to the trash and drag the old version to the Applications folder?”
    I wondered the same thing. I’ve kept all the versions going back to 10.0.0. But without the pre-upgraded projects and events, they are likely worthless (unless you are only starting with new events and projects).
    Dave
  • Andre Grove
    October 24, 2012 at 11:25 pm
    OK been working on this the whole day and night and I have definately lost my project. The event loads but not the project. In the old FCP the event does not load but the project does. All other projects and events updated fine, just the last one I was working on has messed up.
    Tomorrow will try and make a new event in the old FCPX and try and link up the files then duplicate the project and try and convert again.
