Activity › Forums › Apple Final Cut Pro Legacy › final cut pro wont load
Posted by Mike Brannagan on November 30, 2011 at 2:03 amJust bought a new studio 2
I am attempting to load on a used Mac Pro
Former owner had adobe products and pro logic loaded
I am getting a notice saying Final cut pro quit unexpectedly while using theNAU_OxfordDynamics plugin
Jerry Hofmann replied 14 years, 9 months ago 2 Members · 3 Replies -
Jerry Hofmann
November 30, 2011 at 2:06 amI’d suggest a clean install. Erase your startup disk, and install OS et all from the ground up.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Jerry Hofmann
November 30, 2011 at 2:11 amWell, at least that way, you know you’re starting over as if the machine were new sort of… except the hardware is used.
Jerry
Current DVD:
