Activity Forums Apple Final Cut Pro Legacy Final Cut Pro White Box in Viewer and Canvas
  • Final Cut Pro White Box in Viewer and Canvas
    Posted by Megan Heck on March 27, 2012 at 4:32 pm
    Hello,
    I am trying to install FCP 7 on my iMac. After I run the entire install I get a white box in the Viewer and Canvas window. The only time time I can see the correct image in the canvas is when I change the the canvas settings to anything other then black. For example, white, checkerboard 1, checkerboard 2.
    Any thoughts?
    Megan Heck replied 14 years, 5 months ago 2 Members · 2 Replies
  • Rafael Amador
    March 27, 2012 at 4:42 pm
    Probably you have the screens set to display “Alpha”.
    Check the “RGB” option.
    rafael
    http://www.nagavideo.com
  • Megan Heck
    March 27, 2012 at 4:43 pm
    It was set to RGB. But I found a solution, not sure if it temporary. System Prefs > Displays > Color> changes millions to thousands, and then back to millions. It seemed to work, although I’m a bit flabbergasted.
