Activity Forums Apple Final Cut Pro Legacy Final cut pro v7.03
  • Final cut pro v7.03
    Posted by Andy Galler on September 15, 2012 at 11:01 pm
    When I initially loaded Final Cut, I loaded all the options/additional material as well. I believe this consumes 60-70 gigabytes. I would now like to remove these additional materials. The only item that I have been able to find is about 16 gigabytes in Library/Application support/Final Cut Studio. I would like to know where everything else is so I can remove it. Alternatively a full de-install would work, as I have my preferences saved elsewhere, and then I could just reload the basic program, but I am unsure whether a simple de-install would do the trick.
    Any help would be greatly appreciated.
    Thank you,
    AG
    Hariharan Swaminathan replied 14 years ago 2 Members · 1 Reply
  • Hariharan Swaminathan
    September 15, 2012 at 11:26 pm
    Just reload the disc of the items that you want to remove. I would start with the base final cut 7 disc and chose the option that you would want to uninstall. That should do it.
    I see a you stated you have deleted from the application library folder. That might basically corrupt that particular piece of software… let’s say if it’s a motion, sound track pro etc.
    Best way is to do it through the disc. Hope it helps.
    | Hariharan Swaminathan |
    photographer | film maker
    http://www.ihariharan.com
    http://www.vimeo.com/ihariharan
    http://www.youtube.com/ihariharan
