Activity › Forums › Apple Final Cut Pro Legacy › final cut pro – v4.5
  • Enzo Tedeschi
    May 4, 2006 at 5:01 am
    Make sure your firewire device is powered on before you start FCP. If it still doesn’t see it, try the Refresh AV Devices command. Pretty sure it’s in the same menu. Then ensure that External Video is set to All Frames. That should take care of it.
    Enzo Tedeschi
    ____________________________
    Editor
    Sydney, Australia
