Activity Forums Apple Final Cut Pro Legacy Final Cut Pro to Sony Vegas
  • Final Cut Pro to Sony Vegas
    Posted by David Williams on February 18, 2011 at 7:49 pm
    Hello
    I need to create a quicktime file in FCP and have it moved to Sony Vegas.
    Does anyone know if I will run into any compatibility issues moving from FCP into Sony Vegas?
    FCP project is
    Vid Rate 29.97 fps
    Frame Size 1440*1080
    Compressor HDV 1080 p30
    Data Rate 3.2
    Mike Sabatini replied 15 years, 7 months ago 2 Members · 2 Replies
  • David Williams
    February 18, 2011 at 8:49 pm
    Thank you for your help
  • Mike Sabatini
    February 26, 2011 at 2:11 am
    Hi. Actually I do this pretty often. I render my project to ProRes422 in Compressor and save the file to a Mac compatible HD.
    Connect the HD to a PC running Mac Drive and import the files into Vegas 10. No problems, no ridiculous file sizes. Render to the format of choice from there.
    Mike
