Activity Forums Apple Final Cut Pro Legacy Final Cut Pro to Flash (OT)
  • Final Cut Pro to Flash (OT)
    Posted by Michael Allen on August 10, 2006 at 8:10 pm
    I’m creating a presentation in Macromedia Flash MX 2004. When I use an AVI file (which others have suggested), the video and audio slow down to an unusable rate during playback (like slow motion) of the file. I’m having to use a WMV file for the video portion of the presentation. Is there any way to import and use the AVI file for the video section with better results? Is there a specific way to import and use video in Flash that is better than file -> import?
    Can anyone point me to a good source on this topic. This is a coorporate gig and the clips are about 30-40 sec.
    Mike
    John Fishback
    replied 20 years, 1 month ago
    2 Members · 1 Reply
  • John Fishback
    August 10, 2006 at 8:44 pm
    If I understand you correctly, you want to play a video inside a Flash movie. If that’s it, I suggest encoding the video to a flv. You’ll need to use the SparkPro codec in MX2004 (I think). The newer On2VP6 codec is MUCH better, but you may have to use Flash 8 instead of MX. Check out the Macromedia Flash forum on the Cow for more info.
    John
    Dual 2.5 G5 4 gigs RAM OS 10.4.3 QT7.0.3
    Dual Cinema 23 Radeon 9800
    FCP Studio 5 (FCP5.0.4, DVDSP4.0.2, Comp2.0.1, STP1.0.2)
    Huge U-320R 1TB Raid 3 firmware ENG15.BIN
    ATTO UL4D driver 3.50
    AJA IO driver 2.1 firmware v23-28
    SonicStudio HD DAW, Yamaha DM1000, Genelec Monitors
