Activity Forums Apple Final Cut Pro Legacy Final Cut Pro to compressor with cluster problem
  • Final Cut Pro to compressor with cluster problem
    Posted by Jean Deraps on November 19, 2009 at 6:35 pm
    Up until recently I’ve been having no problems doing the following. In the qmaster control panel I set up “Quck cluster with services” and set the compressor service to use 6 or 7 cores. From Final Cut Pro i send the clip to Compressor and render using the cluster I set up. When I do this I get:
    Status: Failed – HOST [**computer.name.here.local] Final Cut Pro generated an error or unexpectedly quit
    FCP hasn’t quit though. And when I just drag and drop a .mov on compressor to render with the cluster, I don’t get this error. Does anyone have an idea of what is going on?
    BTW: I’m on Snow Leopard 10.6.2, latest release of FCS, lots of disk space and memory.
    Aaron Neitz replied 16 years, 10 months ago 2 Members · 1 Reply
  • Aaron Neitz
    November 19, 2009 at 6:46 pm
    Unhelpful answer: I’ve had nothing but errors when trying cluster rendering & “send to Compressor.” I’ve taken to making QT ref movies when I need full cluster speed.
    I’m still on Leopard with FCP 6.
