final cut pro to after effects and back 16:9 question
Hi all first time working with 16:9 had a question hope someone can help me with work flow/settings…I’m trying to go from final cut pro to after effects, then back to FCP for output to DVDSP, however when I import the rendered item from after effects to final cut pro I see a vertical “squish” below is my workflow
Final Output: DVD 16:9/4:3 letter boxed (DVDSP)
1. Captured footage from canon xh a1 shot in hdv format down converted (via camera)
2. Sequence settings in FCP:
Frame Size 720 x 480 NTSC DV 3:2
Pixel Aspect NTSC CCIR 601 DV 720 x 480
Anamorphic checked
Field Dominance Lower (even), Quicktime video settings compressor DV/DVC PRO/NTSC <-----should this be none? 3. Export quicktime from final cut pro 4. Import footage into after effects set up a new comp (settings: NTSC D1 Widescreen Square Pixel, w: 864, h: 486 pix aspect Square pixels 16:9) 5. Render from AE and import footage back to final cut pro. 6. Footage looks squished. When I test render a comp from AE with only motion graphics (with a some perfects circles with NTSC D1 Widescreen setting out of AE and bring it into FCP it seems fine, just when adding video there seems to be a problem. I'm thinking it's the square vs. rect. pixels again, but when I try settings in AE that have any 720 x 480 setting, the ouputted render appears letter box in the timeline of FCP. Is it my export from final cut or my render from after effects, I have no problem going from FCP to DVDSP, it's just going from FCP to AE then back, I need to do this so I can create an open/lower third etc.. What should my settings be for my export from Final Cut? What should my settings be for my render from AE? Any help would be most appreciated.
