Activity Forums Adobe After Effects Final Cut Pro to AE And back questions
  • Final Cut Pro to AE And back questions
    Posted by Bob Flood on April 4, 2007 at 6:22 pm
    Hi
    i think this is my first post here!
    we are using FCP 5.1.4 and AE either 6.5 or 7, and are finding color differences on material exported from FCP, processed in AE, and then imported back to FCP.
    WE originate with Green Screen DVCPROHD footage, then i export from an editied timeline using animation, best, millions, etc. Our AE artist then knocks out the green and gives me back an Animation file with alpha, also best, millions, etc. However, i am seeing a shifting in the gamma levels as well as some color saturation issues. I think we have covered all our bases with the quality and settings of the FCP exports, so i want to make sure all the variables are set correctly in After Effects, things like color space, color profile conversion, itu color and all those little check boxes and preferences.
    If I am asking for a weighty tome of reply because of complexity, just point me in the right direction for more info
    thanx in advance
    bee eph
    “I like video because its so fast!”
    Bob Flood
    Greer & Associates, Inc.
    Bob Flood replied 19 years, 5 months ago 3 Members · 4 Replies
  • Russell Lasson
    April 4, 2007 at 6:25 pm
    So FCP is YUV and AE 7 is RGB from the way I understand it.
    So when you go from FCP to AE 7, select the footage and choose interpret footage. At the bottom of the box there is an option that says “Expand ITU-R 601 Luma Levels.” Select that. It should compensate correctly.
    I never really figured out how to do it in AE 6.5 but it had something to do with the levels filter.
    -Russ
  • Danny Princz
    April 4, 2007 at 9:43 pm
    have your artist import your file and render it back out WITHOUT KEYING.
    just simply render it back and import it.
    figure out which settings allow for your workflow to preserve the image as closely as possible.
    This takes whatever is being done during the keying phase out of the equation.
    who is that masked man…
  • Bob Flood
    April 5, 2007 at 1:59 am
    Hi, and thanx
    As painful as it might be, i am glad for the honest answer:
    YUV-RGB differences will drive you n-u-t-s, nuts! There are NO known ways to equate the two color spaces… no known formulas
    We have been trying something called “the sheer codec” by Bit jazz. If i export from FCP using the Sheer 10 bit RGB codec, and have the AE artist render it out the same way (no itu expansion) the stuff comes back pretty close. I do it in QT conversion, 960×720, and setting the RGB translate in the sheer options for
  • Bob Flood
    April 5, 2007 at 2:11 am
    Hi, and thanx
    We have been trying something called “the sheer codec” by Bit jazz. After a lot of experimentation i found that if i export from FCP using the Sheer 10 bit RGB codec, and have the AE artist render it out the same way (no itu expansion) the stuff comes back pretty close. I do it in QT conversion, 960×720, and setting the RGB input range in the sheer options for full range, and leave it alone on the AE side, adn that seems to work the best, although its still not perfect, but its a lot easier to correct.
    thanx again and hope this helps
