Activity Forums Apple Final Cut Pro Legacy Final Cut Pro Timeline
  • Final Cut Pro Timeline
    Posted by Zoran Gajic on March 11, 2009 at 8:17 am
    I was thinking of something
    when we editing the DV material and our workspace is selected to be DV PAL (example), and when we are applying the effects and color correction logically we will increase the data rate of material so what is happening, by selecting the workspace are we putting the limit of data rate and any additional work that we do will not jump of the DV quality or not?
    thanks
    Jerry Hofmann replied 17 years, 5 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    March 11, 2009 at 3:21 pm
    Well if I understand your post, when you render DV it is recompressed to DV again which is a bit of a loss, but it has to go down about 5 generations before you’d notice it much. One render = one generation loss.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
