Activity Forums Apple Final Cut Pro Legacy Final Cut Pro Suite 2/ Boris problem
  • Final Cut Pro Suite 2/ Boris problem
    Posted by Bobby Mikel on January 11, 2008 at 5:25 pm
    I am running FCP Suite 2 and Boris Red 4.1.
    I have a project that uses Boris transitions. The project looks fine in FCP. When I export to MPEG-2 using compressor it strips the Boris transitions. (All other transitions are from FCP and they are reproduced in the MPEG file.) The last frame of the outgoing clip freezes and it then cuts to the next clip. Does anyone know what I can do to resolve this problem?
    Thanks in advance,
    Bobby Mikel
    Production Assistant
    Jacksonville State University
    Bobby Mikel replied 18 years, 8 months ago 2 Members · 2 Replies
  • Chris Babbitt
    January 11, 2008 at 11:17 pm
    I had this identical problem a couple of years ago with Boris FX. I can’t remember the cause, unfortunately, but it seems to me that it might have had to do with the change to IBM processors in the G4. Nevertheless, I think it only occurred when I exported directly from FCP to compressor rather than making a reference movie first, or vice-versa.
  • Bobby Mikel
    January 14, 2008 at 4:57 pm
    Chris,
    I made a reference movie it worked fine. Strange that it it only has that problem with Boris transitions.
    Thanks for the help,
    Bobby
