Activity Forums Apple Final Cut Pro Legacy Final Cut Pro stereo audio
  • Final Cut Pro stereo audio
    Posted by Daniel Vockins on May 30, 2005 at 11:32 am
    Hi all,
    I’m new here and also a very big novice with the program.
    Basically my problem is that I have now finished editing but am left with audio only recorded for one speaker (not that it matters but the left) and I cant seem to do anything about it. Seems basic but nothing i do or my firends are doing is helping. If i copy and paste one side of audio to a new layer they still both come out of the same side.
    Cant seem to make it work on the settings either. Hmmm, very annoying considering i’m at the end of it all! just this and i can commit to disc. Any help seriously appreciated am at a loss.
    Best wishes Daniel Vockins
    Jerry Hofmann replied 21 years, 3 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    May 30, 2005 at 3:30 pm
    Double click a clip in the sequence, and use the pan slider in the Viewer’s window to pan it center… or select any number of clips and then envolk the Center pan command from Modify/audio/pan center…
    If you only record one track when you shoot you only get one track.. if both tracks are recording, then change the clip settings in the log and capture window clip tab to be both tracks, stereo or ch1 + ch 2…
    Jerry
