Activity Forums Apple Final Cut Pro Legacy Final Cut Pro shortcut question
  • Final Cut Pro shortcut question
    Posted by Karl Compton on December 16, 2011 at 8:30 pm
    I can use the keyboard to set my in and out points and then make an overwrite edit but after I make the edit the timeline becomes enabled and I have to use the mouse to click back in the viewer. I’m trying to cut the mouse out of the equation. Also, is there a way to navigate to the browser with the keyboard? How do I enable the browser, scroll up and down, and then open clips? Thanks.
    Karl Compton replied 14 years, 9 months ago 3 Members · 3 Replies
  • Jean-christophe Boulay
    December 16, 2011 at 8:59 pm
    All pretty basic shortcuts, so here goes:
    Focus on Viewer: cmd-1
    Focus on Browser: cmd-4
    Navigation in Browser: arrow keys, first letter jump
    Send to selected clip in Browser to Viewer: Enter
    Cue the invitations the RTFM…
    JC Boulay
    Technical Director
    Audio Z
    Montreal, Canada
    http://www.audioz.com
  • Michael Griggs
    December 16, 2011 at 9:02 pm
    The browser window comes by default with a keyboard shortcut of command+4. You can find any keyboard shortcuts and create your own by using the “customize” keyboard layout option under the “tools” drop-down menu. (or you can hit alt+h)
  • Karl Compton
    December 16, 2011 at 9:04 pm
    Thanks for responding so fast. While messing around, I discovered that “q” will jump you from the timeline to the viewer and vice -versa. Thanks for the tips.
