Activity Forums AJA Video Systems Final cut Pro setup for ioHD
  • Final cut Pro setup for ioHD
    Posted by Tony Brave on October 30, 2009 at 4:48 pm
    I have control setup for input svideo. The green light is on. everything look fine but when I open final cut it does not see video. I tried different capture setting: non-controllable, firewire NTSC but it doesn’t bring up video. The thing about it is it used to work. What can I do I have a client waiting now.
    Jeremy Garchow replied 16 years, 10 months ago 2 Members · 1 Reply
  • Jeremy Garchow
    October 30, 2009 at 6:22 pm
    Did you install the ioHD drivers? If so, you need to choose the proper easy setup.
    Hit control-q and choose ioHD NTSC ProRes, or whatever format you need.
    If not, you need to download and install the appropriate drivers for your machine at AJA.com
    Jeremy
