Activity Forums Apple Final Cut Pro Legacy Final Cut Pro serial numbers
  • Final Cut Pro serial numbers
    Posted by Jim Rohner on November 11, 2010 at 4:05 pm
    Working at a small media company with not nearly enough serial numbers for Final Cut Pro. Does anyone know if it’s possible to purchase just a serial number for Final Cut Pro 7 without having to purchase another copy of the program? Or if we were to uninstall Final Cut 7 from one computer, would that then free up its accompanying serial number for installation on another?
    Jim Rohner replied 15 years, 10 months ago 3 Members · 3 Replies
  • Shane Ross
    November 11, 2010 at 5:44 pm
    Sorry, the only way to get the new serial numbers is to buy the software. But, you don’t need to install it again, just delete the system ID and type in the new number.
    Shane
  • Neil Evans
    November 11, 2010 at 5:50 pm
    As Shane said, you would have to buy the software to get a new serial number. Uninstalling as you suggest would be fine as well – provided of course that the copy of FCP you are uninstalling is legal (and its serial number only used on that one machine). Obviously that doesn’t get you an additional FCP license, but it does let you move the existing license to a new system.
  • Jim Rohner
    November 11, 2010 at 7:23 pm
    Got it all worked out. Thanks a lot!
